SOURCE: Canon ImageClass MF6540 scans but has error light
use your computer go to command promt and do ping to copier machine ip add, see there is any reply .If there is reply ,your machine is connected to your p.c.then use the printer driver do a test print.
SOURCE: canon mpc190s imageclass printer error wrong cartridge
Try to remove all ink cartridges, then remove the print head, clean the contacts on carriage with piece of cotton and little alcohol then put all back again.If this not help replace the print head.It's part number is QY6-0037-000.
SOURCE: paper jam red light will
Hi..
red light usually indicates a printer error. on your printer problem is most likely still valid paper stuck on the roller or in part (fixing unit), to be sure you have your printer breaks down all cassing to identify where the problems causing the paper jam.
regards
SOURCE: Canon inmage class mf3010 E202 service error
E202
CIS Unit home position detection error / homeward reading position error
When the same error repeatedly occurs although the power is turned OFF and then ON for several times, execute the following remedies.
(1) Check the connection between the Main Controller PCB and the CIS Unit. (J2)
(2) Replace CIS Unit.
(3) Check the connection between the Main Controller PCB and the Reader Motor (M3). (J11)
(4) Replace the Reader Motor (M3).
(5) Replace the Main Controller PCB.
