Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Fan runs The cooling fan in the top right corner of the tv  runs 24-7 days a week is this normal.
  • 8925858bart Dec 06, 2007
    Mitsubishi and a service tech said there is a fan that runs 24-7.thanks and now I still have a green flashing light and can't turn the tv on.
  • C141B Dec 27, 2007
    I have a flashing green light on the front and tried to reset the TV with no luck. Unplugged and attempted to reset again with no joy! Any items to get TV back to working status?
    Thanks - Greg
    Genius:
  • 1,153 Answers
This may indicate something is overheating. Unplugg leave and let cool.
Posted on Dec 03, 2007
How do I fix a refrigerator that won't cool?
if you are sure the evap fans are running (the ones inside) then only 2 things left.... 1- there is ice build up around the evaporators blocking air flow..... 2- the unit is out of freon.... I really suspect that there is ice around evap, samsung's are not known for having freon leaks.....I would unplug unit for 24-48 hours, then remove ff shelving, then take 2 screws out,(located on the bottom left and right of the evap cover and the one that is behind a plastic plug located in the center about 2/3 of the way to the top of the cover....once you remove the screws, grasp the cover on the bottom right corner and gently pull out to remove cover, being careful not to break the foam that channels air..... once removed check to see where the ice is left.... usually in the top right corner, if so replace the sensor located there... Ken Hawk
Feb 21, 2015 | Samsung RF217ACRS Bottom Freezer French...
Freezer fan dead?
Could be the defrosting that is not working. The fan starts touching the ice build up on the back that then causes the noise. A few days later the fan will get stuck on the ice as it keeps on building up due to no defrosting taking place. Unit will keep running as the set temperature inside the cabinet cant be reached because the air distribution will get blocked of due to the ice build up and stuck fan.
Oct 06, 2017 | Northland 24" Built In Top Freezer...
I have a three year old Amana bottom freezer double doors 25 cu ft. The freezer is working fine but the fridge is not cooling at all. I tried defrosting had it unplugged for two days. Tried cleaning the...
There is an evaporator fan locateed inside top of the freezer compartment. It is normally hidden behind a plastic cover. It should be running whenever the Fridge is calling for cooling. Check to see if this fan is running. My suspicion is that it is not running. Replace this and you should be back in business.
You will see the fan assembly at the bottom right corner of the picture.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5174550&diagram_id=28601573#d28601573
Apr 24, 2011 | Amana ABB2224DEW / ABB2224DEQ / ABB2224DEB...
Where is the location of the coolant fan switch temperature sensor?
V6 2.8L top right rear of engine. Fan also turns on through A/C pressure switch and coolant temperature sensor, but these should operate independent of the coolant temp switch.
V8 5.0L and 5.7L (Heavy Duty) lower right rear of engine above starter.
Base model V8 uses the coolant sensor (top right of engine) and A/C pressure switches (lower right corner of eng compartment on A/C line to turn on the cooling fan. Fan is energized on all applications through the cooling fan relay.
Mar 03, 2010 | 1989 Chevrolet Camaro
My engine cooling fan runs even when the engine is turned off-Do you think it is as simple as changing the relay? Much appreciated, Joe B-
The engine fan circuit is separate from the ignition system and it is perfectly normal for the fan to sometimes be off while the engine is on and sometimes on while the engine is off. It should turn itself off independently. If it runs 24 hours a day without starting the engine then the relay or water temperature sensor will need replacing.
Nov 13, 2009 | 1992 Honda Prelude
2003 malibu cooling fans don't work. I have replace the relay and the temp sensor and still nothing. When ever I disconnect the temp sensor the fans come on and work normally, but later in the day I see...
okay pull the temp sensor connector ( disconnect it) and turn car on if the fans run then its the temp sensor.... part # wt3000.
Theres also 3 relays that turn the fans on in the fuse box cooling mode fan relay @15 which is part number 7234. and cooling one # 1 which is 3604, and cooling fan #2 which is 7236.
I have the same car...give me a fan clutch cooling system anyway of the week. simple and efective no problems.
Feb 26, 2009 | 2003 Chevrolet Malibu
Turns on and off green LED flashes until TV turns back on.
this is a symptom of a bad lamp. for some reason it won't spit out a lamp error. shaking up the lamp will sometimes fix temporarily but you will find replacing to be the answer. if your tv has a fan error, you will get 4 red blinks.
Dec 09, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Fan cooling
Doesnt sound like anything out of the ordinary.  The only things you can do to help remedy that more is run synthetic oil get a right hand side air scoop or cut vents into your undertail panel.,,
Nov 10, 2008 | 2007 Buell XB12X Ulysses
Cooling fan
Dear Friend,
ngfam1 at your service
I am happy to assist you!!!
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK NEXT DAY DELIVERY IF IN STOCK!
Here is the service company I refer my appliance customers too!
A&E Factory Service
A Nation Wide Company. / Available 24 / 7 for arranging appointments! In the USA.
1(800) 905-9505
If this dryer is 10 years old or more do not spend any money on it!
The new ones are much more efficient! If you have to replace it buy a Speed Queen , it will do 8 loads a week for 25 years!
It's the last washer and dryer I will ever buy!!!! And less expensive than a top of the line unit!
You will be fine now!
Bless you,ngfam1
PS. PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM BEFORE YOU SIGN OFF!
Aug 28, 2008 | Smeg SUK61MFX Gas Kitchen Range
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
106 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
