Question about Jandy Lite 2 Natural Gas Pilot Light Heater
My heater will not ignite. The pilot is on but
My heater will not ignite. The pilot is on but when I turn on the switch nothing happens. I just bought the house last year and the previous owner said I had to turn the switch on and off rapidly several times to get it to work. Last year it worked occassionally doing this but this year I have had no luck. Any ideas?
  • 128 Answers
All I can say is check for loose or corroded connections
Posted on Aug 30, 2009
  • 27 Answers
The gasvalve has a pilot solenoid which is powered by in essence a thermocouple called a thermopile which converts heatfrom the pilot to to a millivolt output which is why you have to hold the pilot valve till it makes electricty. The main gas valve goes through a series of safety switches and through the thermostat so if any switch has a badoropen contact the heater will never fire find the bad part with a continuity tester and replace it.
Posted on Jul 20, 2009
SW4P won't light
Sounds like ignition problem check earth & power. If your getting a spark check pilot assembly
Apr 20, 2014 | Suburban 3 gallon Water Heater Pilot Sw4P...
Hi, I have an early model Raypak AT and after switching/turning everything off for Winter, it now won't ignite the main burners - the pilot works but when I "turn it up" nothing happens not a...
Is your pilot light blue with no traces of yellow in the flame? If it has any traces of yellow in the flame the pilot assembly will need to be removed, disassembled and cleaned. If it has a blue flame, and the flame is hitting on the pilot mv generator (either a round rod or flat bar) you will probably need to replace the pilot mv generator.
Jan 09, 2011 | Pool & Spa
When you turn hot tap on nothing happens to the boiler just cold water out of tap when heating switched on pump starts but does not ignite
I think you are working on a RV water heater.
Check the reset on the unit and turn your beakers off and on.
If you are working on a gas water heater is the pilot lit.
If you can get us a little more INFO we can help you better.
May 16, 2010 | Heating & Cooling
Pilot turns on but when I switch to turn it on,
When you light the pilot, are you holding it down for 30-60 seconds. When you release the pilot button, does the pilot flame stay lit? Or does it only go out when you turn the knob to on position. Make sure the pilot flame is heating the end of the thermocouple and that it's a strong blue flame, not a lazy yellow pilot flame. Make sure the tip of the thermocouple is not burn't off, which usually happens with lazy yellow pilot flames. Replace thermocouple is nothing else works.
May 13, 2010 | Coleman 5040-751 BackHome Open Flame Patio...
The burners will not ignite
if the unit is used you might have to removed the burner and clean the pilot sometimes rust built in the hole and need to be clean out. I had the same problem.
Apr 11, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
I have a Intertherm heating and air conditioner it is a Manufactured Home. The furnace model number is E2EB-017HA. When you flip the switch to heat and move the control arm up nothing happens. You can go...
When you turn the on/off switch to on you are turning on the "fan switch" and the blower motor is only coming on. When you turn the switch to cool and move the tempature control lever down you are turning on the air conditioner...So it sounds like your heater is not working. Is the heater electronic ignition or does it have a pilot? If it has a pilot the heater may not be working because the pilot is out and will need to be lit. If it is electronic ignition you will need to inspect the unit to determine what component is faulty. Could be the igniter,gas control valve,ect. Verify that gas is not shut off to unit at line valve and gas control valve on unit.
Oct 07, 2009 | Intertherm Heating & Cooling
Charmglow gas patio heater
Your thermocoupler seems at fault. The thermocoupler is that probe that sits in the pilot flame. It controls the main fuel valve. Make sure that probe is in the pilot flame, better at the tip of the flame and hold the button down for a minute or so after lighting the pilot. If pilot extinguishes, the coupler is faulty. If pilot stays on the heater should fire up when you let up on the pilot button.. Good luck
May 30, 2009 | Coleman (5040B750) Patio Heater
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Won't fire
It may also be the high temp switches under the 2" inlet/outlet header. The 150 degree high-limit switch sits horizontal and corrosion happens often there. But be careful removing as if the header is corroded and the switch is also, water will flow out , so be ready to bypass the heater. You will have to replace the header. Try to jumpe that switch out and I'll bet the heater fires up.
Jul 10, 2008 | Lite On Laars Lite 2 Heaters: 250,000BTU...
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
309 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
