I cannot get any sound from my secondary speakers, only my main speakers. tabwyn
  • tabwyn Jul 19, 2009
    I am using a Kenwood VR-60RS. The main speaker, the subwoofer works. The surround left and right, center left and right and back surround do not have sound. They worked earlier. Then I worked with a technicial who told me to go into the setup menu to try and control the volume on my inside and outside speakers separately. That was my original problem. When I turned the volume up loud enough to be heard outside it was too loud inside. When I tried to manually reconfigure, somehow I lost all of the sound to my other speakers including the outside speakers.
    tabwyn
  • 5,807 Answers
the first thing to do now is to get a notepad and note down how you wire the speakers'
unplugged the unit from the wall outlet and relax.
if you have done, doing it, have all the speakers remove
power it up once again
if the unit wont power up then disconnect all that is connected to the inputs and note it also.
power it up again , if the unit still wont turn on, you have a bad amplifier.
if the unit is powering up, try to connect one to the input only this time lower the volume a little bit
start reconnecting one by one the speaker, or better one first and use it as a tester for each of your amplifier
you need to test it manually which terminal is not working and note it
you will know what speakers might have been busted or the amplifier is busted
if all the speakers are all good, congrats,
the trouble is in your amplifier
in your amplifier check first the settings, if everything OK then time to open up your unit.
if it is still in warranty don't, give a ring on the dealer or visit the manufacturer web site
if you want to further diagnose your unit you will be needing to get the part number of the electronic parts mounted on the biggest aluminum heatsink that you can see,
later a multimeter will do the voltage checking, have someone to do it , it can be done with a help.
you can Google for the electronic part which i have mentioned to know something about it.
hope i have helped you, thanks for using Fixya!
Posted on Jul 19, 2009
    President:
  • 846 Answers
Hello tabwyn,
I'm sorry to hear about the trouble you were having earlier. Id be more than happy to assist you in fixing your problem. I do however need some more information.
1. What type of Amp are you using...make and model
2. When you say secondary speakers do you mean your subs ?
Post back with that information please and I will begin providing you with a solution immediately.
Thank you for choosing Fixya!
Posted on Jul 18, 2009
How to change voltage from American standard 120 V to European 220V
This is for a powered speaker? You'll need an "autotransformer" or "step-down transformer" with a 240VAC primary winding and a 120VAC secondary winding. If you try to just use a plug adapter and power that speaker from 240V, you'll destroy it immediately.
Aug 04, 2014 | Yamaha YSP-4000 Main / Stereo Speaker
How to output sound to a secondary device
Open up unit look for where socket plugs in solder bridge the part of the switch that opens when socket inserted
Jun 11, 2014 | Marantz NR1604 7.1 Channel Home Theater...
What features does a apex tv gt3215 have?
GENERAL
  • TV typeCRT TV
  • Screen size
    32 in
  • Power Consumption Operational
    150 Watt
  • Timer Functions
    Sleep, wake
  • Video Interface
    Composite, S-Video
  • Manufacturer
    Apex Digital, Inc.
FEATURES
  • TV features
    auto volume adjustment
VIDEO
  • Technology
    CRT
  • Aspect ratio
    4:3
TV TUNER
  • TV tuner presence
    Yes
  • Analog TV tuner
    NTSC
  • Reception System
    NTSC-M
  • Secondary Audio Programme (SAP)
    Yes
  • Secondary Audio Program (SAP)
    Yes
  • Channel Coverage
    VHF:2-13, UHF:14-69, Cable:1-125
  • Stereo Reception System
    MTS
AUDIO
  • Speaker(s)
    2 x main channel speaker - built-in - 5 Watt
  • Output Power / Total
    10 Watt
  • Audio Controls
    sound mode
CONNECTIVITY
  • Video interface
    composite
REMOTE CONTROL
  • Type
    universal remote control
  • Supported Devices
    DVD player
CONVENIENCE
  • Closed Caption Capability
    Yes
  • Parental Channel Lock
    Yes
  • V-Chip Control
    Yes
  • Menu language
    Spanish
MANUFACTURER WARRANTY
  • Service & support
    1 year warranty
POWER
  • Nominal Voltage
    AC 120 V
  • Power consumption operational
    150 Watt
DIMENSIONS & WEIGHT
  • Weight
    156.5 lbs
DIMENSIONS & WEIGHT (SHIPPING)
  • Width
    38.7 in
  • Depth
    29.2 in
  • Height
    30.5 in
  • Width (Shipping)
    38.7 in
GENERAL
  • Manufacturer
    Apex Digital, Inc.
Mar 08, 2014 | Televison & Video
Ear sound not working
There are three main reasons for it not to work: Dirty contacts (when an electric contact between the small speaker does not meet the electric circuit that controls and feeds it) in that case you have to clean those parts; Burned speaker ( the only way to fix it is to change it). Or a broken display connective ribbon (it's the ribbon that makes the connection from the phone's main board, to the display board, and the small speaker) the only way to fix that kind of thing is to change the ribbon. These 3 thing are to be solved at a service, rather than by yourself. The fourth reason (which is a secondary reason) is that the speaker is muted, from the phone's menu.. since it's Nokia, you might want to call anyone or answer a call and press the volume + button on the side of the phone or the left arrow key, around the main menu button.
Apr 26, 2011 | Nokia 5200 Cellular Phone
What do i hook the sub woofer to
the sub woofer speaker should be connected to the Center, the main speakers should be set to the front and the secondary ones in the rear....(front = main just in case surround is not on, center = is for that ump / boom sound, rear = that just pass you by (make you look behind yourself)
Aug 30, 2010 | Yamaha RX-V659 Receiver
Only one speaker works - altec lansing computer speakers ADA215
The solution is actually quite simple, due to a design flaw. Altec lansing designed a rather cheap mini din plug-in which can either be replaced or repaired depending on your skill and patience level. Your ground contact is fine BUT the positive contact is not making connection due to the fact that the plastic housing has broken away and pulled the contact with it. This can be super glued back into place or just replaced with a new mono minidin plug-in.
Mar 09, 2010 | Altec Lansing ADA 215 Computer Speakers
The mains transformer in my Logitech x540 has blown (oc on the primary). I've taken it out and its a simple single coil primary and secondary, but there are no markings on it to indicate the secondary...
You would need to rewind the coils.Do not try to do it by yourself if you have no idea what you are up-to...this time it was transformer next time it could it could be your circuit.Take it to a professional,the charges won't be much.
Good Luck.
Dec 27, 2009 | Logitech X-540 Multimedia Surround Sound...
Dead JBL EON 15P-1
did you measure 60vac across total secondary or 60vac from center tap?
Feb 27, 2009 | JBL Eon15P-1 Main / Stereo Speaker
Only plays one track from from DVD sound
Plug in center speaker -- seems right and left speakers are secondary carrying only the background / sound affects.
Jan 10, 2009 | Televison & Video
No sound out of monitor speakers
Is there actually any unknown devices in the device`manager?
Are your monitor speakers USB or do they plug into the audio out jack of your sound card or motherboard???
If they plug into the sound jack, then test the sound output with a pair of headphones.
Hope this helps you narrow it down. Please reply back if you need further help
Dec 30, 2007 | Mag Innovision LT976S 19" Flat Panel LCD...
37 people viewed this question
 Grubhead
Grubhead
