SOURCE: I lost my decimal point
You need to be in add mode, and have 2 decimal places selected for the result.
To change to add mode, make sure the 'K . A' switch is in the 'A' position. To get 2 decimal places in the answer, move the selector in the 'F 6 3 2 1 0' switch to the '2' position.
You can see the above described at
this Sharp.com page which shows the users manual. The manual shows examples.
SOURCE: A DOT AFTER THE ZERO
Hi - I think you have the "Grand Total" switch set. For normal operation set the switch to the central position as below:
Hi - You can download the manual from the link underlined in blue below:
EL-1801P
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: I have done something so the calculator is only
Hello
The floating point number display (FIX) is set to zero decimal digits. All your. numbers with decimal parts are rounded.
Look for a key that says [FIX]. Press it and enter a number say3 If I guessed right (Sharp makes numerous calculators) your numbers will show 3 decimal digits.
If there is no such key look for a [MODE] Button. Press the button. If you have a new screen with differents choices look for Format, Float,
On some older calculators there is a table below the display. At the left of the table one finds MODE--> or -->MODE
If it says there Mode DEG:4 that means to have angles in degrees you enter [MODE][4].
I think I exhausted all possibilities. Without you model number, I cannot do more.
Hope it helps.
SOURCE: Nothing happens when I press a number??
There is no lock button. Calculator may be configured to be in computational mode you are not familiar with: It may be set to do base calculation on base 5, hence the p (pental). Press the reset button on the back, and the default configuraion will be restored.
You should give some time to learn the different mode of calculations.
Hope it helps.
SOURCE: I have the sharp model
To change from fraction to decimal, all it takes is a keypress. (change key)
.Not all decimal results (approximations) will be converted to fractions.
Anyway, if you want to set the calculator to display decimal results only,
Press SETUP
Press 2:EDITOR
Select 1:LINE.
Calculate the amount if you know the total and percentage
For example, if you purchase a computer for $800 and there is an 8.9% sales
tax, how much do you have to pay for the sales tax? In this example, you want to
find 8.9% of 800.
Example
The example may be easier to understand if you copy it to a blank
worksheet.
