Question about Craftsman Garden
My Sears rototiller model 917293310 is in neutral. It won't shift into any other gear. It starts just fine.
  • 112 Answers
It could be the fork shifter of bracket inside that broke. Check her to get better idea and for parts
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=917293310&productCategoryId=1508200&brandId=0247&modelName=TILLER&diagramPageId=00004&componentDescription=TRANSMISSION&documentId=P8120018&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jul 25, 2009
Why does speed control lever return to neutral when going forward ?
this model uses a series of groves cut into mower body to maintain the transmission gear/direction , it's held into groves by a spring just under the cover , if this is broken a replacement can be gotten from sears (part# 164X39) to replace it , it should take at least five pounds of force to move shift lever out of grove to next gear , if not then your shift spring is loose or broken
Jun 05, 2014 | Craftsman Garden
Selecting 3rd gear
Do you mean you can\'t find 3rd gear or it won\'t shift into 3rd gear? If you can\'t find 3rd gear, shift all the way down to neutral, then shift up 2 clicks. On my Suzuki Boulevard S-50 (VS-800) the shift order is 1st gear down, then up for neutral, 2nd, 3rd, 4th, and 5th. Your crotch rocket probably also has a 6th. If the problem is that it won\'t shift into 3rd, then you had best take it to the shop as it is not readily repairable without specialized tools and knowledge.
Oct 02, 2013 | 2003 Suzuki GSX-R 600
Trail blazer gear shift button
Could be the brake switch or the shift lock solenoid. You may be able to turn the key lock to the unlock position, move the shifter out of park, then start the engine in neutral.
The shifter and the shift lock solenoid would need to be inspected.
Jun 19, 2013 | Cars & Trucks
I need 2,3 & 4 gear for Yamaha 1100 special 1982 model
Instructions
    • 1 The gears on a motorcycle run in this order: first, neutral, second, third, fourth and fifth. When you are moving, shifting up from first gear will skip over neutral and shift you right into second gear. The only time that shifting up from first will get you into neutral is when you are not moving.
    • 2 Pull in the clutch lever and tap the gear lever down until it stops. This will signify first gear. Pressing the gear lever down will shift you down one step and pressing it up will shift up one step.
    • 3 Tap the gear lever up one click while still holding in the clutch. This will put the bike into neutral.
    • 4 Start the bike. The bike needs to be in neutral to start.
    • 5 Hold in the clutch lever and tap the shifting lever down to shift to first gear.
    • 6 Release the clutch slowly and give it just enough gas to get moving.
    • 7 Listen to the motor to know when you need to shift. If the engine is making a low grumbling noise, then it will need to be shifted down. If it is making a high squealing noise, then it needs to be shifted up.
Jan 15, 2013 | Motorcycles
Gear shift cable 2005 chevrolet cavalier
Had the same problem. to shift gear manually with your hands. Look under the brake fluid (about a foot down) and there is a flat piece of metal. On the end of it on the bottom is a little rod with a round end. That is where the shift cable connects. pushing it toward the driver side of the car will put it in park. And if you count the number of clicks from park you can change gears. For example: 1 click from park is Reverse, 2 clicks is Neutral, 3 clicks is Drive. That is if it is all the way towards the driver side. Don't force it. when it stops clicking dont push it anymore. Hope this helps.
Jan 20, 2012 | 2005 Chevrolet Cavalier
Craftsman rototiller mod. # 917-294260 won't go into gear
try rolling it a bit. Sometimes the gear doesn't fully mesh correctly. As you try to shift push or pull the tiller juuuust a bit back and forth and try to shift as you do that see what happens. Or go into neutral and rock it then try again.
May 05, 2010 | Craftsman 8.50 Torque Rating Dual...
Rototiller wonts change gears
Try rocking the wheel as you try to shift.
Apr 30, 2010 | Craftsman 8.50 Torque Rating Rear Tine...
Sears rototiller wheels locked up engine runs great
After taking the transmission/frame apart, the drive chain for the tires broke and wedged in the case. I cleaned the rest of the gear box and washed all of the gears and sprockets. Ordered up the chain, gasket and grease. I re-installed and greased all of the pieces and reassembled the case. I used a marine wheel bearing grease for the water resistant properties. I installed a zerk fitting right over the shifting lever. This should help keep the grease on the top end of all the gears. After a few hours it is good to go and works just like new.
Aug 20, 2009 | Craftsman Garden
Craftsman rototiller 3 5 model 917 299130 leaks
Sounds like you are speaking of the float bowl.
It should not have a hole in it.
You could purchase the part from Sears or a small engine shop.
If it were mine, I'd remove the bowl, clean it, and patch with a gasoline impervious material such as JB weld.
Apr 05, 2009 | Craftsman Garden
Need manual for craftsman 6 hp tiller model 917293310
you can get a manual from sears. if you go to the sears parts web site,put your model number in and go to the decal section the manual is there for a wopping $3.92 part number is 166007. i hope that helps you out.
Mar 10, 2009 | Craftsman Garden
Garden Logo
437 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
