Question about GE GSS25SGMBS Side by Side Refrigerator
Ice Dispenser jams up and won't release ice - GE GSS25SGMBS Side by Side Refrigerator
  • 714 Answers
Sounds like you need to replace the icemaker!
Posted on Jul 18, 2009
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
ICE dispenser gets jammed often
ice gets jammed in the ice dispensing system. the ice forms properly but when I dry to dispense it gets all frozen and jammed.please help
Jul 05, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a Jenn-Air refrigerator #JCD2389DES. The ice maker became stuck and kept delivering ice cubes even after dispenser was released. I finally opened the freezer door and got it stopped. Now it...
Yes it could be either, BUT I would go back and make sure that everything you did to stop it the first time is undone. Is everything setted correctly? Is the switches in the right place?
Neither the solenoid or the microswitch could cause the problem you had before, so I would suspect something is not right with the ice maker itself.
Jun 16, 2011 | Jenn-Air JCD2295HES Side by Side...
SIDE BY SIDE ICE MAKER MAKING ICE BUT NOT
Perhaps the dispenser have a, ice jam or it's clogged. Using a hair dryer, blow some hot air to the dispenser to see if the ice - if any- melts.
Aug 30, 2009 | Hotpoint HSS25GFP Side by Side...
After my ice dispenser jammed my ice maker stopped making ice
make sure you reassembled it correctly.
icemakers can be stubborn with their safety features and will not work if not propperly reassembled
Jul 30, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice dispenser on kenmore side by side refrigerator
If the release mechanism is jamming you might need to replace ice maker itself. The kit is only about $10 cheaper so I would change out the icemaker
Jun 19, 2008 | Refrigerators
Ice dispenser jamming
There is a revised bucket that's made to prevent that.
If your refrig has a steel liner order WR17X11308
If it has a plastic liner order WR17X11315
Oct 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSS25SGMBS Side by Side Refrigerator Logo
180 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
