Question about Goodman CKL42AR42 Air Conditioner
Hey, I have a goodman cple30-1 that won't "kick on" it just lightly buzzes when the fan should start moving The inside fan works fine just no cold air.. thanks Im trying to save the $150 house call
  • slaker Jul 18, 2009
    I checked all the fuses none have been tripped. the outside unit fan doesnt come on but when it should, it emitts a buzzing sound for about 1 second. it sounds like the power is there the fan just won't turn over
    Thanks
    Ron
  • slaker Jul 19, 2009
    Thank you
    Ron
  • 334 Answers
What exactly is buzzing? is the compressor running without the fan? It may be the contactor buzzing and if nothing is running this may indicate that the breaker is tripped as the control voltage may be coming from the indoor unit. Let me know what you find out
seth
Posted on Jul 18, 2009
  • seth veloso Jul 19, 2009
    sorry so long to get back, did not know you responded. Your fan motor needs to be replaced, the bearings are probably tight, can be checked by trying to spin by hand with power off
The outside unit fan kicks on but the inside unit does not.
It sounds like your blower motor has gone out., the buzzing would be the motor trying to start but maybe locked up. You most likely have a completely burned out motor so you no longer have any buzzing. The motor can be changed out by a do it yourself-er with some mechanical and electrical know how. If you do it yourself be sure to replace the motor run capacitor.
Sep 02, 2012 | Goodman CKL36AR36 Air Conditioner
My goodman condensing units fan won't start to turn on its own
Hello, usually this is a sign of a bad capacitor. Replace the capacitor.
May 21, 2012 | Heating & Cooling
Our goodman furnace igniter trys to kick in, but blows cold air. Gas company came checked furnace and told me goodman igniters tend to have this problem of them working fine and then blow cold air at...
it sound slike the presure switch is not working , if it is not lighting try jumping it out it may work some times you can fool it in to working
Feb 21, 2011 | Goodman Heating & Cooling
Inside fan turns on when outside unit is in defrost mode when heat is selected. This causes it to blow cold air for about 10 to 15 minutes prior to the outside fan starting.
The inside fan will run while the unit is in defrost. The electric heat strips should kick on to help prevent you from feeling this cold air. When the unit is in defrost it is essentially running in the A/C mode. You should make sure the electric heat elements are working then go from there.
Dec 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Fan is spinning on compressor but air inside not cooling house
that means that it can be the capasitor for the compressor is faulty or it can be one of the windings in the compressor is burnt
Sep 26, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman a/c unit outside not coming on. buzzing
Sounds like compressor is bad...taken out by a bad contactor.
Aug 17, 2009 | Heating & Cooling
I noticed some straining noise coming from my a/c unit today. The fan on top of the condenser runs fine but as soon as the compressor tries to kick on the fan stops for a split second and you get a kind of...
You amy ahave a bvad capacitor on the outside unit. It starts the fan and the compressor. You can change this yourself. Open the outside panel and you will see a silver canister with terminals out the top. Replace this and I think your problem will go away. On the cap. it will say something like 30uf 5uf 370 ot 440 Just get these numbers and get a new one. Russ
Aug 14, 2009 | Goodman CKL24AR24 Air Conditioner
My ac works inside, fan comes on and blows fine ,but outside fan wont kick on just makes buzzing noise and no cold air just air
Hi, normally when your freon is low, system won't work, look for filter dryer, follow high pressure tube from compressor to condenser, filter dryer normally have sight glass where you can see freon moving in system, if there's bubbles, you need freon, freon should be charge until glass get clears, hey remember to always charge from low or liquid side of system.
Aug 02, 2009 | Heating & Cooling
A/C comes on but fan inside does not --- Help!
check thermostat not capacitor if it works in the on position then it should work in auto
May 26, 2009 | Goodman CLJ30AR32 Air Conditioner
Goodman air conditioner will not turn on outside
When ever you hear a buzzing like you are hearing means one thing one of the fuses on the outside disconnect box is bad. Only getting 1/2 the power. Find the bad fuse and get the same size and will be good to go. ken
May 02, 2009 | Goodman CLQ36AR49 Air Conditioner
Goodman CKL42AR42 Air Conditioner Logo
839 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
