Question about Garden
I'd like to know the grade & quantity of oil to do a service on a Suffolk Punch 35s cylinder mower that I have just been given. Also if I can run it on unleaded petrol or will I have too use an additive. The serial number is 35 S L 80162
  • Derek Gebbard Jul 19, 2009
    Thanks for the info. I just found the manual on the net & it said 0.6 litres of oil. When I tried to put that it in it overflowed at about 0.5 litres. Drained some out, gave it a kick in the guts & it started first go. Probably first attempt to start in at least 20 years, I'm impressed.
    My 35s model is also quite different than that shown in the manual but all is in good order so hopefully I won't need it.
  • 714 Answers
I checked the site and said just 4 stroke kawasaki engine oil and unleaded gasoline
Posted on Jul 19, 2009
How much oil in a Suffolk punch 35s
Geoff, Check the attached links, manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://www.oldlawnmowerclub.co.uk/sites/default/files/opmanual/Suffolk%20Punch.pdf
Suffolk Punch OWNERS MANUAL
Small engine repair How to drain and change the oil in small petrol engine
Jul 02, 2016 | Garden
Suffolk Punch 35s not starting
carburetor have a setting level for its fuel , check the floating control adjust fuel level , also check spark plug current is there,just by rotating engine and keeping spark plug out of cylinder , just keeping it with engine body.
Apr 12, 2014 | Garden
I need to set up the dellorto carb on the 35s suffolk punch
Running only with full choke is a fuel problem. Unhook fuel line from carb. it should run good. If not go back the line. Check the fuel cap vent.
Mar 25, 2014 | Garden
Replacing Tap on Qualcast petrol tank
It should just screw out, there is a thread on the plastic fuel tap, they can be pretty tight.
Jun 09, 2013 | Garden
Replacement bottom blade for suffolk punchl lawn mower
Hi Keith,
You can find spares here:
http://www.espares.co.uk/search/lawnmowers/suffolk-punch/p/1116/2173
If you google suffolk + punch + spares you should be able to find more websites which supply blades.
Hope this helps!
May 30, 2011 | Garden
I have a Suffolk Punch 35s mower and the petrol cap leaks badly and won't stay on whilst mowing, do I need just a new cap to fix it?
Yes, that's all you need. At some time yours was cross-threaded, That means that it was forced on wrongly, and broke the thread.
Mar 24, 2011 | Garden
Qualcast Suffolk Punch 35s lawnmower running problems
There is a small idling mixture screw on the side of the carburettor.
As the engine is not well suited to the carb. it mainly runs on the idle setting!
As long as you are not leaving the choke on. This is a little tab on the top of the carb. You start with it set on C then soon set it on the middle position, and after about 3 mins turn it off.
Jul 12, 2010 | York Yankees Bedding MLB Comforter
Please advise on where to puchase replacement parts for old Qualcast punch classic 30s lawn mowers
Hi howardandjan, You call it "old Qualcast punch" if it's called Qualcast punch it's not that old, it was originally called Suffolk punch (after the horse) and came in 14" and 17" cuts, the 30s (30cm approx 12") was originally called suffolk colt. when Qualcast took over just about all the british cylinder mowers Atco,suffolk,webb etc they started swapping names about but you should be able to get parts from any good mower shop try winchester garden machinery in hampshire always found them helpful
Aug 30, 2009 | Garden
Garden Logo
390 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
