Question about Dell 924 All-in-One InkJet Printer
I have a 3-4 year old Dell All in 1 924 Printer. I've been getting paper jams of late. It's seems to be pulled to the right. Could I have a worn roller on the left? I've adjusted the paper guide but this seems to be too easy a solution. Is it time to just get a new printer?????
    Brigadier General:
  • 4,088 Answers
Usually, these problems are connected to paper dust on the rollers, or the rubber has gotten slick with use. Use dry, clean fingers to rub across the rollers as they are turned by hand. Try cleaning the interior out with a vacuum blowing, not sucking. These rollers hardly ever wear out.
Posted on Jul 18, 2009
I have a Dell 5100cn and I'm getting paper jam check tray, it seems that when it goes to pick up the paper it can't
077-907 Paper Jam - Push Side Button:
  1. Turn the printer off using the power switch on the right side of the printer.
  2. Press and hold the up and down buttons while turning the printer on. ...
  3. Press the down arrow until IOT DIAG appears, and then press Select ( or ).
  4. Digital Input appears on the LCD, press Select ( or ).
More items...
How to Troubleshoot Internal Paper Jam or Multiple Sheets ... - Dell...
or try this link...
how to fix paper jam Dell 5100cn Google Search
Oct 27, 2017 | Dell Office Equipment & Supplies
Dell 1720 printer single-sheet feed stopped working
Pull out the paper that is jammed and continue.
Nov 29, 2012 | Office Equipment & Supplies
Paper jams frequently
Use a flashlight and check the paper path thoroughly. You may find bits of old paper, dust and debris. Perhaps a thorough blowing out with compressed air will help. Also, the paper feed mechanism may be damaged or worn.
Sep 11, 2012 | Dell MFP 1815dn,Laser fax copier printer
For every single print job, paper gets jammed. Heve tried several paper brand always same issue. Printer is 7 years old.
if getting paper jams, it is most likely that there are issues with paper grab wheels etc. If the printer is 7 years old, it is more than likely cheaper to replace than to repair it.
http://accessories.us.dell.com/sna/productdetail.aspx?c=us&cs=04&l=en&sku=224-9642
Sep 13, 2011 | Dell 1815dn All-In-One Laser Printer
HP C4385 display reads Paper Jam continuously
check the paper jamed or not other wise try to reset your printer
Oct 03, 2009 | HP LaserJet P2015dn Printer
How to release the paper jam on printer DELL 5100cn??
first remove ink cartridge from printer.then check power suply is off.then open the front door then pull down 2 spring then check there is not any paper jam.
also check in front side there is not any paper jam.if jam thehn pull softly u casn do it man.
Dec 30, 2008 | Dell 5100cn Laser Printer
A940 doesn't feed paper correctly
My DELL A940 printer used to jam every time with the paper pulling to the right.
Solution - there was a pen jammed in the mechanism !
I was about to trash the printer when I looked deep into the workings from above, holding the printer to the window to get bright sunlight into it. I could see a round ballpen laying in the groove at the bottom.
Hooked the pen out and all is back to normal.
This may not be your problem, but its worth a look.
Dec 26, 2008 | Dell A940 All-In-One InkJet Printer
How to solve repeated paper jams in Dell 3010 laser printer
Replace the pick rollers. If you're out of warranty it'd be mighty expensive to have Dell replace them, but, if you call them, they can get you access to a website (I can't remember the name...sorry) that has walk through tear-downs with pictures of each and every step. (Only do this if you're handy and have time)
Otherwise, replacement is the next option.
Typically Jams on this unit are from worn rollers. :)
Good luck.
Oct 20, 2008 | Dell 3010cn Laser Printer
IBM Infoprint 1332 paper jam
one of the paper path sensors is blocked. check underneath tonner check if the sensor is playing freely.
Aug 19, 2008 | IBM Infoprint 1332 Laser Printer
Dell 924 All-in-One InkJet Printer Logo
121 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
