Question about Amana Refrigerators
Why would my refrigator be freezing my food set at the lowest setting it can be set on
  • Amana Master
  • 1,606 Answers
If it has a damper at the top left wall , the damper is bad or the refrig control (possibly circuit board) is bad .The damper closes to reduce the air flow to the refrig yet the freezer section can still get colder if needed . The refrig control or circuit board for the fridge control , works the damper . If you feel air coming thru the damper , it is not closing , causing your food to freeze .
Posted on Jul 19, 2009
Black and decker mini refridge freezes food on lowest setting
The lower the setting the colder the fridge should be, the dial should be turned to the right. A refrigerator should be kept around 35-36 degrees F
Jan 03, 2012 | Food Processors
Food freezes in the refrigator
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
May 20, 2010 | Whirlpool GD5SHAX Side by Side...
Refrigerator is freezing food
your damper door located between the refrige and freezer compartment is iced up fully open,you need to defrost it, then see if this closes when the cold control is adjusted
Jan 16, 2010 | Frigidaire FRS26H5AS Side by Side...
Food in refrigerator is freezing
check the damper door between the freezer and refrigerator compartments,it most likely has frozen in the fully open position allowing cold air into refrige compartment all the time,you will see ice build up around the damper door unit,remove the door unit defrost,replace and then see if it moves when you change the refrige cold control
Jan 12, 2010 | GE Refrigerators
Refrig in camper keeps freezing food even when on lowest temp
It's either the thermostat or the door seals leaking Since its freezing the refridgeration unit is fine
Oct 22, 2009 | Rv Motorhome Dual Co & Lp Gas Alarm...
My side by side refrig. keeps freezing everything. It is turned lowest setting. Model GLRS2677AW6
Hi, this problem is going to be with the running thermostat2.gif (cold Control). It has gone bad and stays open which in turn will keep the compressor running continually and will cause the fridge2.gif to get colder and freeze food. It can normally be located in the control panel inside the fridge (it is the control that has wires, the other is the damper). Locate the thermostat and replace it. If you have any other questions or concerns please feel free to comment again. Good Luck!! Mike
Oct 09, 2009 | Frigidaire Refrigerators
Freezing Items in refrig
number one is the lowest setting...try that
Apr 01, 2009 | Amana AFD2535DES French Door Refrigerator
Food freezing in refrigerator and water dripping
The problem with the water is that the drain tube is plugged. The easiest way to fix this and to save money is to unplugg the refrigerator and leave the doors open all day. This will thaw out the drain tube without a service technician coming out. That will fix that problem. With it freezing the food on the where its not supposed, This may be a bad cold control. But try unplugging the unit for a day with the doors open and this may fix both problems. (i know it will fix the water issue)
Nov 24, 2008 | Whirlpool Refrigerators
Refrigerators Logo
329 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
