Question about NetGear WGR614 54Mbps Wireless Router (obwgr614_1)
Set up xbox live and need to open ports
Im trying to set up xbox live and i need to open the ports on my netgear wirless router
  • 4,338 Answers
Go here, select your model and follow the steps indicated:
http://www.portforward.com/routers.htm
Posted on Jul 19, 2009
My NAT type is strict and i wanna make it open how for xbox live
Check out this website. It has set by set instructions on how to set change the NAT type to open. You have to open certain ports for xbox live which are also listed.
http://portforward.com/english/routers/port_forwarding/Netgear/WGR614/Xbox_Live_360.htm
Sep 15, 2010 | NetGear WGR614 Wireless Router
Hi im trying to open my nat on my router due to me playing xbox live can you tell me what i need to do
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
May 08, 2010 | NetGear DG834G Router
Hi folks ive got a damn problem getting on live everytime i try to sign in it just says ive got internet connection but cant connect to live fully..... when i do live connection test it says ive got a port...
I was searching the web concerning this problem, and apparently there's a good amount of people dissatisfied with the results from their netgear dgn2000 router when hooked up to Live. You can pick up a pretty good router from Best Buy for under 40 bucks. That sucks that you're ISP and xbox support aren't helping. I usually go past Netgear and shoot for Linksys or D-Link just because I've had good relations with them. Good luck getting back to gaming, man.
Jan 04, 2010 | Microsoft Xbox 360 Console
When I secure my wirless network xbox live wont connect
If your xbox is also connecting wirelessly, you have to input also the wireless security key on your xbox to be able to connect.
Jun 29, 2009 | NetGear RangeMax WPN824 Wireless Router...
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
NAT settings are set to Strict
Go to this link this will help you with your problem.
http://www.portforward.com/english/routers/port_forwarding/routerindex.htm
Once your on this page select the model of your router (look into Netgear).
On the next page select XBOX live. After this, this will give you instruction how to open ports for your xbox live.
Aug 04, 2008 | NetGear WGT624 Wireless Router
NAt Settings
Are you sure that you are forwarding the correct ports? I also have xbox live, and it seems the closer my router is to my xbox, the better the NAT gets. (wierd) Honstly though, unless you are encountering some extreme lag, I wouldnt worry about it.
Apr 04, 2008 | NetGear WGR614 54Mbps Wireless Router...
Xbox 360 live and netgear WGR614
Down load the new firmware and install it in your router.
http://kbserver.netgear.com/products/WGR614.asp
Use UPnP. If your router supports this. Turn it on. The router will work out the ports it needs to open for Xbox live. If your router does not have this feature, check the manufacturers website for the latest firmware. (also make sure portforwarding and/or DMZ is turned off as they interfere with UPnP)
Oct 16, 2007 | NetGear WGR614 Wireless Router
Nat settings on netgear wgr614 wireless router
Hello --
Most NAT settings can be found, on modern routers, under the WAN setup of the router interface. Normally, it is set to Secured with the option of setting it to Open. Click Open and apply changes, giving the router a moment to reset the software and re-broadcast transmissions.
This comes secured for public consumption because the normal consumer would not create a WAN (wide access network) at home. However, gaming consoles (PS3 and Xbox 360) require this because of the P2P hosting that most online multiple-player games require. Setting it to Open full-duplexes the transmissions without restriction (since gaming console connections are "supposed" to be secure anyway).
After you've set the NAT settings, restart the gaming console, test the 'net connection and confirm it is reading your now Open NAT settings.
Oct 15, 2007 | NetGear WGR614 Wireless Router
NetGear WGR614 54Mbps Wireless Router (obwgr614_1) Logo
238 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
