Question about Frigidaire GLTF2940ES Front Load Washer
Front loader my washer gets ti the final spin and stops will not spin fast anymore
  • 714 Answers
Try RepairClinic.com they can help with your problem
Posted on Jul 19, 2009
My washer stops during the final spin cycle, it will drain the water but the clothes are still soaked....every time, we have to re-situate the clothes and manually give it one or tow good spins then it...
Hi from retired Englishman in SW France @ 14:15 Wed afternoon.
What make and model- front or top loader, please?
Does it seem to struggle and be intermittent frequently, particularly when spinning? Is it not running at true spin/fast speed?
Also how old/used- I'm trying to ascertain if it is the main motor's worn brushes or the belt slipping or something else!
Cheers,
John C
Feb 02, 2011 | Whirlpool Washing Machines
I have a Fridgidaire front loader. It completes the regular wash cycle, but clothes are soaking wet- it's not doing the final fast spin. When I select the drain/spin option, it drains and eventually...
Either an off balance load (unlikely if it happens all the time), a bad door switch, or a bad motor control board. Easiest repair is to try replacing the door switch, failing that, i'd call someone in to test the speed board.
Apr 05, 2010 | Frigidaire ATF6000ES Front Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Frigidare front loader washer GLTF1040ASO
your bearings are shot your washer needs to be rebuilt but it is cheaper to buy a new washer
Dec 26, 2008 | Washing Machines
Washer won't final spin
After charging me $275 to change the water pump, the repairman said I needed a new computer board for another $160. I went & bought a new washer - this time a regular top loader mechanical washer with no computer. The repairman said computerized washers & front loaders in particular have lots of problems. He said top loader Whirlpools have the least problems.
Nov 13, 2008 | Frigidaire ATF6000ES Front Load Washer
Washer won't spin in final spin out
Hello harley1964dm
Welcome
You said, you have a Frigidaire front loader and it will not spin out in the final spin would you please help me. thanks
For a Frigidaire usually ,
If the washer won't spin.
Many times it's because the load is too small. Add 1 or 2 similar items to help balance the load.
If it does not remedy the problem try unplugging the machine for 5 minutes which will reset the system!
Let me now how it goes.
Huuum
Please remember to leave a rating
Oct 11, 2008 | Frigidaire ATF6000ES Front Load Washer
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore 44042 - No spin cycle
The front load washers are supported by springs on the top and shocks on the bottom.  More than likely you broke a spring on the top or cracked one of the shock mounts which causes and unbalanced load all the time.  Will it go through a spin cycle with no clothes is it?
Oct 17, 2007 | Kenmore 44042 Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
140 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
