Question about iLO 2600 Television
My 32" TV Does Not Work Period
My son opened the back and the fuse was blown. We replaced the fused and it blew immediately.
Important to NOTE: Walmart NOR Ilo will replace the TV or get it repaired!
  • 44 Answers
You have a short in the power supply .
you need an experienced teck to check the tv. Your problem may be a shorted transistor or something more complex. Let me what aera you are frome, maby i can recomend a teck that is factory authorized to repair your tv.
Posted on Nov 20, 2007
Why does the fuse immediately blow on my power door locks? how to fix this?
You have a short somewhere in the system. Maybe one of the lock actuators or a switch. To test disconnect all locks and switch then replace fuse if don't blow start with driver door and reconnect lock check fuse see if it blew if not reconnect switch active lock check fuse see if ok. Continue with each door separate using same steps until fuse no good you will have found short. Replace shorted part.
Apr 30, 2016 | Cars & Trucks
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
Bad storm, lightening strike outside then TV went off and will not come back on.
I would start with your power supply. If you took a surge it is possible that you only blew a fuse. If it is a blown fuse, make sure you only use the same type fuse.
Apr 12, 2011 | Westinghouse SK-32H240S Television
I was watching TV and it just cut off. There is no power light on and the outlets are working and the cord is firmly in.
good day sir/maam, chances are yout tv just blew a fuse, when a fuse blew up, there are several reasons.
  • It protects your tv from further damage.
  • a part of your tv got bad, causing it to blew.
You have a choice of calling your service center/dealer or do it your own.
If you decide to do it yourself, these are the steps you may need to do.
  1. Open the TV's back cover, to access the circuit. locate the blowned fuse.
  2. you may need to pull out the entire board, to test it.
  3. test the switching regulator IC/transistor for shorts, (you may need a multitester).
  4. check for open low value resistors, less than 100 ohms.
  5. You really need to find the cause of the blew up fuse. part by part checking is necessary,
  6. replace the bad parts and test again.
  7. if everthing else fails, you really need to call your service.
note: if you simply replace the fuse without tracing the blew up shorted bad part, chances are the fuse may blew again.
Oct 02, 2009 | Vizio L32 32 in. LCD HDTV
Sanyo 32" lcd tv.power from the mains but no sound or there a fuse in the tv.
My 52" sanya lcd tv blew a fuse - take the back off and follow the power cord up and you should have 2 fuses there - probably the one on the left has blown out. You'll have to learn about the fuse you need - I had to get mine out of NV. Good luck!
Jun 18, 2009 | Protron PLTV3250 32 in. LCD Television
Main fuse blown on CT-32G11 32" Panasonic TV, Replacement fuses continue to blow.
If the main fuse keeps blowing, check the horizontal output transistor for a shorted condition and diodes in that section as well.
Jan 12, 2008 | Panasonic CT-32G11 32" TV
Full sound not working
I had the same problem and also traced it back to two of the four 7-amp fuses were blown. I replaced the fuses, but they immediately blew again. I used higher capacity fuses (10 amp) to see how bad the problem was and those blew. Testing the problem a third time with the speakers disconnected yielded the same results.
There's an internal short in the system.
The solution? Don't buy RCA again.
Nov 12, 2007 | RCA RS2656 Shelf System
Fuse blown
ok well i would check for a open diode in the main ac to dc power supply then check all resistors that look lick they may be low ohms but high watt check to see if you might have a open pico fuse from primary power supply to the regulator check and see if you have stand by voltage this would be easily checked on the power off oan on button get back to me k
Nov 01, 2007 | RCA F32450 32" TV
Fuse location on tv
a fuse is a small glass tube about 3/4" to 1". it is located near the end of the power cord inside the tv. it is located in the power board supply circuit. there are several reason why fuse blew up. 1. sudden surge current/voltage in your area 2. shorted in either power supply or horizontal deflection circuits. when replacing fuse, be sure to change it with the same value. but if after replacement has been done and the fuse blew again, there is a short in the circuit as stated in reason no. 2. refer to a qualified service technician if you are not inclined with this job. good luck!
Feb 12, 2007 | Panasonic CT-32HXC43 32" TV
Televison & Video Logo
54 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
