Question about Kodak EASYSHARE M1063 Digital Camera
Camera will not stay on
Battery is fully charged. It turns on, the Kodak software image appears in the viewer, the lens extends out, but then it immediately shuts down. Any suggestions?
I have basically the same problem. I sent it in for repairs. It came back and I followed the instructions they came be. BUT IT STILL WONT WORK. it's worse then before, the logo wont even come anymore ! :(
Posted on Jul 22, 2009
Will not stay on
Hi.
Start replacing the batteries. Test with fully charged batteries.
If the camera has power, but lens does not extend, ensure you are not in PC mode. If you are not in PC mode.
If the camera does not turn on at all, then it can be a broken contact to battery slot, or a faulty control board. Sometimes the ribbon cable that connects to main board and also to battery is broken or lose.
If the camera is turning on but lens does not extend, then it is usually a lens error.
The best thing to do is calling Kodak at the number listed on the owners manual, pointing out that you did not cause the fault, and that you did not do any improper use of the camera. Ask them a quote on repair.
You an also get a quote from a third party service here: Repair.
Check first the batteries and setting.
Jan 25, 2010 | Kodak EasyShare C913 Digital Camera
Lens does not extend
Here are the steps:
1. Make sure you will install a new or fully charged battery/batteries into your camera. Please use lithium batteries Ni-Mh or rechargeable Batteries (2000 M.Amp or higher).
2. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
3. Turn on your camera without the memory card.
In order to organise your repair or Trade up please Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 21, 2009 | Kodak EasyShare C875 Digital Camera
Staying on and blurriness
1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. Please also try to upload new firmware: Connect the camera with the computer. Turn the camera on. Click onto the link and follow the instructions. http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=11033/11261&product=EKN032924 If you're still experiencing problems. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Dec 18, 2009 | Kodak EASYSHARE Z1285 Digital Camera
THE LEN IS STUCK ON EXTENDED POSITION AND WILL NOT RETRACT TO THE OFF POSITION? BATTERY WAS FULLY CHARGE.
If no power on the camera:
Here are the steps:
If there is power on the camera, bnut the lens is stuck:
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
Dec 10, 2009 | Kodak EasyShare DX7630 Digital Camera
My camera will not stay on is off and stuck with lens out
If the lens doesn't retract on most digital camera the camera also will not turn ON. It is connection or wiring between camera power and camera lens.
What Kodak Rep will ask you to do are:
1. Remove the battery and the memory card of the camera
2. Check if your using a recommended battery and if its new or fully charge. batteries for Z1275 are Ni-MH rechargeable; CRV3 Lithium; 2AA Lithium
3. Insert the batteries back in the camera in correctly
4. Set the camera in Auto mode (its the camera icon on the dialing mode of the camera)
5. Try to turn it ON
If still will not turn ON and the lens will not retract
6. If your using a rechargeable battery Kodak Rep will ask you to charge the battery until its fully charge.
If your using a disposable battery they will ask you to try to use a new battery out from the box.
After all those steps still the camera failed to work, it will be send for repair. The number of the Kodak support line is 1 800 235 6325 (23KODAK)
Nov 20, 2009 | Kodak EasyShare Z1275 Digital Camera
Kdak MX1063 won't stay on...
Try cleaning the contacts from the battery and the battery compartment of the camera. I had the same problem, used a cotton swab to clean and this fixed it, it seems to be a common problem.
You can also try the official Kodak troubleshooter at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Aug 09, 2009 | Kodak EASYSHARE M1063 Digital Camera
Camera will not stay booted up
It seems that the Milli Amps on your rechargeable batteries are to low you will notice on each battery it will show the amplitude purchase a higher amplitude.
May 12, 2009 | Kodak EasyShare DX4330 Digital Camera
Camera won't stay on
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 11, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak Easyshare CX7530 won't stay powered on
I have the exact same problem. Can anyone help?
Apr 03, 2008 | Kodak EasyShare CX7530 Digital Camera
Kodak EASYSHARE M1063 Digital Camera Logo
216 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
