Question about Samsung Gravity SGH-T459 Cell Phone
Samsung Gravity Shuts Off Randomly
It started with my phone shutting off everytime i set my phone down.
It has pregressed to the point where it shuts off no matter what.
It's ruining calls and texts HELP
This only worked as long as I shut the keyboard gently. The problem really seems to be mechanical. When sliding shut, the battery is jostled just enough to lose contact and shut the phone down. Placing a folded piece of paper between the battery and the non contact side of the phone to increase pressure slightly.
Hope this works for you as well
Posted on Sep 03, 2009
I have the SAME problem with my Gravity phone. I haven't figured out how to fix it yet, but it helps if you slide the phone open (and close it) carefully and slowly. Try that and it will shut off less frequently.
Posted on Aug 11, 2009
  • grecoj2 Aug 12, 2009
    Ok, think I may have actually fixed this problem.
    Go to Phone Settings (lower right hand of icons menu)
    Then go to 4. Phone Settings
    Go to auto Key Lock and turn that "Off"
    Then go back and go to 3. Display Settings
    Go to Backlight, then Duration
    Then change "On' to 30 seconds
    and change Dim to "Off" < very important that you do that
    It should stop shutting off randomly now, or at least shut off a lot less.
    I changed my phone to these settings this morning (just trying to tweak the problem away) and it hasn't shut off all day. Which is really good, considering it usually shuts off atleast once every hour.
    Let me know if that helped.
Mine does the same thing so u need to get a small piece of paper and fold it and put it on the side where it doesn't touch. Or u can just get a new battery from cell phone shop.net they have really cheap cell phone stuff their.
Posted on Sep 11, 2009
    New Friend:
I tried both the solution posted by grecoj2 and the paper shim suggested by oqoqoqo. The phone has worked fine since. (It used to shut off randomly, among other problems.) I am currently trying it with just the paper shims (I set the autolock and dim back ON.)
I have a paper shim at the end of the battery opposite from the contacts, and a shim between the battery and the back cover.
I used to work at Moto, and handled a lot of phones. Many are very sensitive to momentary loss of power caused by small mechanical shocks. The Samsung Gravity is (if this is really the problem) EXTREMELY sensitive.
Posted on Dec 07, 2013
How do i turn off windows 8
1. In Windows 8.1, from the Start screen, click the Power button and select Shut down.
If you can't see Start screen, point the mouse to the bottom-right corner of the screen, click Settings, then click Power, then click Shut down.
2. From the Start button, select Shut down or sign out and then Shut down.
Jul 08, 2014 | Computers & Internet
Turn off windows 8
My acer all in one z5600 runs for awhile and then shuts down very annoying!!!
Start by cleaning the fan or fans, heatsink, and vents, you may have to open the computer. When you open, you may as well replace the Thermal Paste on the CPU and Graphics Chips. Overheating will cause shut downs, heat sensors set to detect a set temp. will shut down to protect vital components from heat related damage. ALSO, Open Control Panel, Power Options, set to High Performance, open Change plan settings, under Plugged In, set both to Never, open Advanced Power settings, go through thr Advanced settings set Sleep and Hibernate to Never, Adjust to your preference. It's a good idea to Always shut down your computer when not in use, it will last longer and a reboot everyday will reset the machine. Make sure ALL your Windows and Acer Updates are current.
Feb 15, 2013 | Acer Z5600 All-in-one 23" 4gb 2.8ghz 500gb...
Hp pavillion vista won't shut down
I think your at the point to do a Full System Recovery. Do you have a Factory Recovery Partition? You didn't supply the Model of HP or the OS you are using?
Jan 24, 2013 | Computers & Internet
Refrigerator keeps running The compressor is not shutting off regardless of how cold it gets. If the temp is set at 35 for the frig and 0 for the freezer, the compressor keeps running even when the temp...
your cold-control that you adjust has gone out,be it dial adjust or electronic unplug the dial one and see it will shut down,be careful on unplugging on an electronically controlled unit as you can ruin the control board if not powered down before board is unplugged
Jul 27, 2010 | GE Refrigerators
LG enV touch keeps shutting off when charging
I would replace the battery and see if that helps with this problem
Mar 30, 2017 | LG enV VX9900 Cellular Phone
Slow logoff times
The most likely culprit is a program that is hanging up the shut down process. Before you shut down, close all open programs, including the ones on the task bar.
Feb 28, 2009 | Microsoft Windows XP Home Edition
Microwave shuts off before time elapes
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
The best place to order Panasonic parts is Tritronics. You can also call them at 866-779-5835.
If you prefer, you can find an authorized Panasonic servicer here.
Dec 07, 2008 | Panasonic NN-T990SA Microwave Oven
Phone blinks once and turns off
did you follow the charging instructions or did you start using it right away, because its very possible if you ignored the initial charging instructions that you could have ruined the battery from the get go. which would explain all the symptoms you listed
Dec 06, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Samsung Gravity SGH-T459 Cell Phone Logo
4,841 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
