Question about Panasonic Panafax UF-490 Plain Paper Laser Fax
Comm 503 What is the definition for comm code 503 on a Panafax UF-490? I have a list of comm codes for Panasonic fax machines but 503 is not on the list.
  • 25 Answers
That is "CS of modem is not able to turn ON during training." It could be a bad SC circuit board, but usually that's a bad line or connection. Get your phone lines checked out by your phone company.
If that doesn't do it, then you'll have to replace the board in the fax machine.
Posted on Jan 25, 2008
Panasonic Panafax UF-790 Fax did not complete logging into memory. Comm. Journal comm. 212 What do I do?
its a receiving error code means a computer was trying to fax you and it didnt connect properly
Nov 12, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Codes mean?
We have exactly the same problem, no manuals, no explanations of all codes.
Thank you!
Apr 02, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Panafax UF 885 resets itself when trying to print comm journal
sounds like your firmware might be shot and it needs to be reinstalled, if your in canada i can recomend a tech
Nov 03, 2008 | Panasonic Panafax UF-885 Plain Paper Laser...
Comm. code 400
the 400 code is some cases is due to incorrect transmission levels, try turning of memory tx and send directly, or could try adsl filter on the line if needed, there are things that techs will be able to adjust if necessary
Apr 08, 2008 | Panasonic Panafax UF-490 Plain Paper Laser...
Communication code 408
it means line quality is to poor or recievers fax mc is no good. if it is only happening to a few numbers then is probably not a fault with your mc
Oct 26, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
How to get fax reports
Your only option is to have it print out automatically after every 32 transactions, print out after every transaction, or print out only when there was an error with the transmission.
That parameter is Comm Journal and you can get to it by going to Function 7, option 4. That should give you a fax parameter table. You want options 12 and 13. Set 13 to "1" if you want it to print out every 32 transactions. Set that to "2" if you don't.
Set 12 to 1 for Comm Journals Off, 2 for Always, and 3 for Incomplete Only (errors).
Oct 02, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
How do i program the machine to print only failed fax confirmations?
Press "function" button Press "7" Press "set" Display reads - Set Mode (01-99) No.= Press "4" Press "set" Display reads - Fax Parameter (01-99) Press 1 then 2 Press "set" Display reads- Comm. Journal 1= off 2=always 3=inc. only (printout when comm. has failed) Select 3 press set Press "stop"
Jul 03, 2007 | Panasonic Panafax UF-790 Plain Paper Laser...
Panasonic UF - 560: Comm Journal page does not print
I could not find to the manual for your particular model, however the following should be close enough. Although you have set the Comm Journal to "On" you have to set the paramater to "Always" Download the manual at: http://service.us.panasonic.com/OPERMANPDF/UF585.PDF Look at page 131. I think that will take care of it. IF NOT - PLEASE let me know before you rate this solution. I will research it further. Ed
Jun 28, 2007 | Panasonic Panafax UF-560 Plain Paper Laser...
Panasonic Panafax UF-490 Plain Paper Laser Fax Logo
539 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
