Question about Mtd LAWN MOWER PART # 683-0439A DECK Assembly-60.5 CM
Push down the clutch and it won't start mtd riding mower it will start sometimes, but when it has ran for awhile it won't start at all.It is a 1998 model.
  • 714 Answers
Sounds like the starter or the carb is flooding out!
Posted on Jul 18, 2009
MTD RANCH KING RIDING MOWER TURN KEY AND JUST CLICKING NOISE. DID PUT NEW SOLENOID TWO YEAR AGO. OLDER MODEL RANCH KING.RAN AT END OF GRASS YEAR BUT NOW JUST CLICKS ????
make sure all terminals are clean & tight on all + & - from battry to starter check that terminals are snug on ends of cables if still clicks put screw driver across selenoid with switch on from hot cable to hot cable both should be red you mite get a little spark thats ok should start if so cut off & try w/key sometimes switch or regulator will cause same problem sometimes they will keep starting with key
Feb 12, 2015 | Mtd Garden
How to adjust brake/clutch on mtd riding mower
Go to MTD website and download owners/or repair manual for your tractor ,then adjusting the brake will be easy !
Jun 29, 2014 | Mtd FASTATTACH MANUAL SLEEVE HITCH
How to adjust the clutch/brake to push easier?
It's all spring pressure,I would suggest oiling the pivot points !
Jun 21, 2014 | Mtd Garden
Mtd 42" riding mower rear drive belt keeps popping off pulley
Hi, check the idler pulley arm and return spring on that belt. Its most likely not pivoting freely allowing the belt to loosen when you operate the clutch, regards Phil.
Jun 10, 2012 | Mtd Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Mower starts but won't stay running
check the inside of the cap. Check the underside of the gas cap for a cardboard disk. Remove the disk, and try starting again. My mower had same problem, and I removed the disk and suddenly it ran like there was no problem at all.
Aug 13, 2011 | Mtd 22" Yard Machine Push Mower
Yard machine riding mower will not start
check all of your known safety switches!
Clutch has to be pushed in
seat switch (sit on mower)
blade disengage switch
Finally check your starter soleniod between the battery and the starter and look for fuses and check them out in the process
May 18, 2009 | Mtd 22" Yard Machine Push Mower
Mtd LAWN MOWER PART # 683-0439A DECK Assembly-60.5 CM Logo
195 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
