Question about Refrigerators
Light wont burn in frig
Light wont burn in my whirlpool frig model#ET25DKXXN01
  • 714 Answers
Have you checked the bulb or the light switch?
Posted on Jul 18, 2009
Paid 2 people to look at it and still wont work
check air flow at frezer. also were is freezer/frig dial set to? place it in the middle. also look for freezing up on back wall and bottom of freezer. DO NOT SET FREEZER/ FRIG DIAL ALL THE WAY TO FREEZER!!!. PLACE HAND WERE YOU CAN FEEL AIR FLOW AND TURN DIAL AND YOULL SEE WHAT I MEAN.
Feb 20, 2014 | Whirlpool Refrigerators
Whirlpool wont turn back on after running fridge
check for 120 volts , does the light come on when u open the frig door?
Dec 11, 2012 | Whirlpool ET8WTKXK Top Freezer...
Whirlpool Frig/Freezer - Frig side too warm at 60 degrees
Check for another fan to cool the fridge side. It could be bad.
murf427
Aug 01, 2012 | Whirlpool Refrigerators
Whirlpool frig divider door getting hot
that is normal,, unless it will burn you,,there is a little heater in there that is to keep frost from forming and the doors sticking,,to the cabinet,, if it is getting so hot it will burn you, you will need to call a service tech out,, that is a real hard repair to do yourself
Jan 24, 2011 | Whirlpool Refrigerators
Bulbs burning and causing frig to get hot.
I need the model number you may have a short and lights are reaming on while door is closed. This sounds like a recall or fire hazard Unplug let the area cool remove the bulbs or risk property damage until confirmed what model you have Sea Breeze
Dec 13, 2009 | GE Refrigerators
WHIRLPOOL FRIG AND FREEZER NOT COOLING EHOUGH
Well there a couple things you can check. Pull away from wall and remove the lower cover over the compressor. Either the compressor is stopping on and off too much or the evaporator fan or the condenser fan is stopping while you do not know it. Tell me how hot the top of compressor is. We may have a bad motor starter and start capacitor along with overload. Let me know what you find and I may very well get you going again, Sea Breeze
Oct 21, 2009 | Whirlpool Refrigerators
Whirlpool conquest sibe by side GS6SHAXKQ01 freezer has defrosted and food is thawed
I have whirlpool conquest model GS6SHAXKQ01 - Came home to puddle of water, everything in freezer is melting, frig is getting warm. Lights come on both sides...Suggestions? Thanks
Sep 29, 2009 | Whirlpool GS6NBEXR Side by Side...
Changed bulb in frig and light still not on. Frig is older whirlpool. est age is 15 years. i thought bulb was just burnt out. everything else still working. replaced old bulb 15 w with an "appliance" bulb...
I would stick with an appliance bulb. The glass in those is more resistant to extreme temperature changes.
Your problem sounds like it could be that the door switch has burned/corroded contacts.
If you have a continuity meter you can remove the switch and test it to see if it's working.
BUT, FIRST, TURN OFF THE BREAKER TO THE FRIDGE!!!!
If you don't get continuity thru it, soak it in rubbing alcohol for about an hour. Let it dry for about an hour, and test it. If it's still not working, replace it.
If you need help with the continuity testing, let me know.
Apr 30, 2009 | Whirlpool ET8MHK Top Freezer Refrigerator
Freezer works but bottom of frig wont cool.
check to make sure nothing is blocking door from closing all the way
Jan 18, 2009 | Jenn-Air JBL2086HES Bottom Freezer...
Whirlpool gold conquest refridgerator
if u find out let me know. when we turn both frig/freez switches off the frig light comes back on flashes to number 6. it still seems cold be like this 2-3 days the food still seems cold. good luck. jax, fl
Mar 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
