Question about Maxtor OneTouch II 300 GB Hard Drive
My magic jack only rings once and the phone picks it up
  • 1 more comment
  • ourblueheave Jul 19, 2009
    It only rings onceand l would prefer it ring at least four or more times
  • seth veloso May 11, 2010
    what do you mean by the phone picks it up?
  • Patunia Apr 08, 2013
    Voicemail picked it up.
My magic jack phone stopped ringing and the handset says no line
It sounds like the magic jack is not getting power. Is it plugged into the computer, or a wall outlet? Is the blue light on?
If it is plugged into a computer then unplug the Magic Jack and reboot the computer wait until it reloads and then plug the Magic Jack into a different USB port.
If it is plugged into the wall, Then unplug it for 5 min and then plug it back in.
If it doesn't come up and it is still covered by Magic Jack open up a chat with them at the link here. http://www.magicjack.com/contact.html
Sep 17, 2017 | Lands Phones
Is it possible to forward calls to my MJ to my cell phone?
I presume your MJ is Magic Jack.
If so, the answer is yes.
You have to go to
http://my.magicjack.com
Login
goto Your Account
Call Features
Forwarding
a screen appears
Enter Phone number and click forwarding ON
Click submit
Your calls will be forwarded to that number from then on
**************** CAUTION *******************
The Magic Jack phone will no longer ring nor receive calls, but you can dial out.
ONLY the number you forwarded it to will ring!!
May 25, 2017 | Lands Phones
How do i get magic jack to take a message
Instructions
    • 1Dial your telephone number from your MagicJack phone. You can also click on the "Vmail" button on your computer desktop to use the Magic Jack software phone.
    • 2 Push the "Star" key on the phone when the virtual answering machine picks up. If you are calling from the Vmail software phone, click on the "Star" button.
    • 3 Input the digits "1234" when prompted for your Magic Jack voicemail passcode. This is the default passcode.
    • 4 Push the "0" button. This allows you to set a new passcode and change your voice message recording. Input your new passcode and follow the system prompts to record your custom voice message.
Oct 17, 2014 | Computers & Internet
Magic jack customer service
If your tv has internet access and you can run their software on it then it will, otherwise no.
Aug 30, 2014 | magicJack Two, 2 Magic Jack Plus Voip...
Magic jack is a VOIP service. If you do not have a good strong consistent internet service it will not work for you.
Apr 23, 2014 | Lands Phones
Magicjack problems
Phone is not workin...not ringing on ether end goes straight toice mail...
Dec 09, 2013 | Android Apps
How to recieve a fax ?
If your printer is connected to a modem make sure that the port has a dial tone. To check for dial tone, try to plug in a phone to the same port that you printer is connected to. If it doesn't have dial tone, you might want to check with your phone provider. Or you can plug in the printer straight to a wall jack.
Once the printer is connected to a line that has dial tone, you can then setup the printer to receive faxes. To set it up, on the control panel of your printer, press on Setup > Fax Setup > Ringing and Answering.
If you have an answering machine, set your printer to pick up 3 rings higher than your answering machine. If not, set it to pick up on the 5th ring that way you will still have time to pick up the phone if it's a voice call.
If you have a voicemail service from your phone provider, you'll need to contact your phone provider to get a distinctive ring feature. Once you'll have that feature, you can assign a distinctive ring to your printer. You can find that under Fax Setup > Ringing and Answering > Ring Pattern.
May 29, 2012 | Lexmark Interpret S405 Wireless All-in-One...
Maxtor OneTouch II 300 GB Hard Drive Logo
301 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
