Question about Toshiba SD6100 DVD Player
Our toshiba dvd player only displays movies in black and white
Replace the mainboard this is a common problem with this dvd im afraid
Posted on Jul 18, 2009
5 Suggested Answers
MikeNJ1964
  • 398 Answers
SOURCE: sony dvp ns50p dvd player
If you are using the s-video jack to connect the DVD to the TV, the jack could be loose or the wire could be bad. The s-video cable has 2 signals, the black-and-white (luminance) and the color (chroma). If the chroma signal is not getting through, the picture will be in black and white.
Posted on Sep 01, 2007
SOURCE: Movie playing black and white
Its a black and white movie.
Posted on Jun 13, 2008
Bubbabear64
  • 2794 Answers
SOURCE: DVD Player won't play movies in color
It could be the av cables being faulty or shorted. Try replacing them with another set and see if it goes away.
Posted on Jul 21, 2008
skotkolr
  • 558 Answers
SOURCE: Picture playing in only black & white
progressive scan is on turn it off
Posted on Dec 13, 2008
Dvd playing hooked up to an old t.v. plays in color when i hook it up to my lg tv it plays in black and white?
My DVD player only plays in black and white - TOSHIBA FORUMS
forums.toshiba.com/.../My-DVD-player...plays-in-black-and-white/.../47...
39L1350U) and am trying to hook up the DVD player. ... My DVD player only plays in black and white ... My DVD player is an old Sony. .... Was using and S-Video connecting cable to the TV. ... suggested to use VIDEO instead of COLOR STREAM, I changed that in the TV menu, plug the red and while at the back of TV where ...
No Color When My DVD Player Is Hooked Up - Community ...
community.insigniaproducts.com/...DVD-Players/...Color...My-DVD-Pla...
Jul 14, 2014 - I hooked up my DVD player and I have no color. ... you need to use the connections on the left side of the TV or on connections on the back. .... is turned on, which can cause this black and white image issue you're having. ... If the Player shows correctly on a different TV with the same hook up, and different ...
The picture from a disc player displays on the TV in black ...
Jan 17, 2016 | LG Televison & Video
I own a toshiba 19dv500 and am having trouble viewing a dvd, the system is working but only in black and white, no colour\???
Hello there,
A black and white picture is most often due to a faulty or incorrect RGB (red/green/blue) connection or cable.
If you are using a composite connection (red/white/yellow RCA jacks), you have probably connected the yellow plug to a socket labelled Pr/Pb, Cr/Cb, or Y - on either the DVD player or the TV - most probably the TV. The yellow needs to be connected to a socket labelled "VIDEO". If you connect this to any socket labelled Pr/Pb, Cr/Cb, or Y, you will get a black and white picture.
If you are using a component connection (red/green/blue RCA jacks), one of the plugs is either not fully inserted into the socket or is in the wrong socket. If you remove any one of the R/G/B plugs, you will get a black and white picture.
If you are using a SCART cable (UK / AUS), you may have a bent, damaged or disconnected pin.
I suggest you check and correct the connections between your DVD player and TV. If you are unable to locate the problem, please try another cable as the one you are using may be damaged. If you are still unable to locate the fault, please let me know the brand and model number of the DVD player and how it is connected to the TV. If required, I can also draw a diagram showing the correct connections.
It would also be useful to know whether this "fault" suddenly occured, or whether you have just connected the player to the TV.
Hope this helps - please let me know if you need further assistance.
Regards,
BElectric
Mar 03, 2011 | Toshiba Televison & Video
Movie only playing in black and white how do I fix that?
To fix out this problem you need to go to the video settings
This is happening because you have selected NTSC video format
Select the PAL video format and you would be able to see coloured movies again
Feb 27, 2011 | Toshiba SD-3950 DVD Player
My dvd player only plays movies in black and white
my dvd player only plays movies back in black and white...not color. why?
Jan 21, 2010 | Cyberhome CH-DVD 300 DVD Player
Our dvd player now only works showing movies in black and white. What can we do? It use in color but for some unknown reason the movies are in black and white.
someone must have pressed something mistakenly.
Check the DVD remote and press PAL/NTSC. The color should appear.
Or you could also check the video wire at the back of the DVD and TV, maybe it has loosed contact.
I wish you all the best.
Jan 07, 2010 | Toshiba SD-2800 DVD Player
Movie only displays in black and white
there might be any problem in ur vedio card or check for drivers.........or else it is a problem of the display which u need to change
Oct 15, 2009 | Toshiba SD7200 DVD Player
Show movies in black and white no color
unit is in a progresive mode. need to turn back to interlaced.
Jun 01, 2009 | Sony DVP-NS575P DVD Player
Playing movies in black and white
Use a scart lead to connect it to the TV, that should cure it.
Dec 08, 2007 | Sony DVP-NS315 DVD Player
Toshiba SD6100 DVD Player Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
