Question about GE WBSR3140DW Top Load Washer
Have water under tub on ge washer - GE WBSR3140DW Top Load Washer
4 Suggested Answers
SOURCE:
Oceti
  • 51 Answers
SOURCE: GE WHRE5260E1WW Washer
The mixing valve needs to be replaced. It should be under $50 and is easy to do.
Posted on Jan 23, 2008
  • 119 Answers
SOURCE: washer is filling too much and water is coming out overflow
you need to clean the pressure swith hose on the lft side of tub small rubber hose stop use in liqid soap
Posted on Jan 31, 2010
richroth
  • 9472 Answers
SOURCE: 2008 GE PROFILE WASHER. THE WASHER WILL RUN
You need to replace the "lid switch". Here is a link to the part you need. Here is a link to a video that may help you.
Posted on Dec 02, 2010
The washer filed with water and quit working
if it doesn't agitate but everything else runs the most likely cause is the coupling under the tub is worn out and needs to be replaced. They are usually plastic and require the entire tub to be removed.
May 24, 2013 | GE WBSR3140DW Top Load Washer
My GE top loader leaks at the spin cycle when it is letting out the water
Sounds like the tub seal under the tub where the transmission goes into the tub. Replace the trans and seal.
Mar 15, 2011 | GE WBSR3140DW Top Load Washer
GE Profile washer...model: WPRE6150HOWT sesr:
i'd check the drain pump-there is a seal where it attaches to the motor-leaks often there, also could be a leak in your tub seal between the tub and transmission, also sometimes the outter plastic tub gets a crack in it and leaks
Feb 15, 2010 | Washing Machines
Ge washer leaks when you let it fill to top
feel in the back of your outter tub towards the top and chances are you will find a hole ge's love doing this if it is not under warranty you can repair with some JB weld with out replacing the tub
Oct 09, 2008 | GE WBSE2090A Top Load Washer
Water leaking where motor goes into the drum
there is a tub seal under the spin tub that proab needs replacing open the front panel then raise the top then grab the agitator and **** up on it hard it should snap out then unsnap the splash ring around the outer tub take the little bolt out of the agitator drive loosen the nut on the spin tub and remove it keep going down till you get to the tub seal replace it then reassemble
May 22, 2008 | GE WHRE5260E Top Load Washer
Oil on floor under washer
Oil is generally not a good sign. It means that the tranny seal is blown OR it means that the tub seal is bad which allows water to enter the tranny (water is heavier than oil... if water gets into the tranny it will displace the oil and force the oil out)
This being a GE? I'd wager that a tranny job is in order. If the machine is less than 5 years old it's under warranty so you'd call GE at 1-800-GE CARES. If it's more than 5 years old? Your washer is no more than a boat anchor. Get a new washer, preferably a Whirlpool. The repair cost for a new tranny will out-weigh the value of the machine.
Hope this helps.
Mar 23, 2008 | Kenmore 22642 Top Load Washer
Jan 23, 2008 | GE WHRE5260E Top Load Washer
GE top load washer leaks on floor
Check your hoses mostly the small hose going from the side of the tub to the water switch these come off a lot. you need to look and see if the seal is leaking from the center of the tub you do this by putting water in the tub and just looking around the bottom of the tub and transmission
Dec 29, 2007 | Washing Machines
Washer leaking
There are several things that will leak under a GE washer. The the usual suspects are drain hose connections, or hoses that have cracks or holes. I would inspect the hoses first as this would be the easiest fix. The other thing that can causes problems is the wash tub seal on the bottom of the tub. If the spanner nut (under the agitator) comes loose, the seal will unseat and the tub will begin to drip (I've had this one happen to me). Another cause can be the wash tub itself (I've also experienced this one). Inspect the wash tub for cracks. The tub can develop stress cracks and begin to leak. Especially if this is a washer that was involved in a move. To access the inside of the machine, the front should come off by pushing under the front lip of the machine with a putty knife. There are metal clips that hold the front to the top. Look in the crack with a flashlight to locate them. Push in with a putty knife to release and the front should just come off. I hope this helps you.
Jul 05, 2007 | GE WBSE3120B Top Load Washer
GE WBSR3140DW Top Load Washer Logo
62 people viewed this question
Top GE Washing Machines Experts
Marvin
Marvin
geapptech
jimorris77
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
