Question about Maytag Neptune MDE5500AY Electric Dryer
MY 4 year old neptund dryer just quit, element is ok, un-plugged for 5 min, no help, can you help, Thank you
  • 234 Answers
It's only a bad thermal fuse if it's an electric dryer.
It could also be a tripped circuit board or a motor.
The motor is probably still good since it's only 4 years old.
Good luck :)
Posted on Jul 19, 2009
  • Maytag Master
  • 1,606 Answers
You have a bad thermal fuse (the white piece located on top of the elemant ) After replaceing , check the vent hose for kinks or lint blockage .
No heat when drying
I have a Miele WT2780 where the fan motor stops spinning. This will stop the dryer from working even though the element heats up. The failure of the fan will not blow the air across the heating element and thus into the drum. New motors fitted are around £400 min. I am never going to buy another Miele - mine failed after 6yrs.
Another problem is the thermostat can trip. This is a small button inside the machine (TURN OFF MAINS ELECTRIC AND UNPLUG FROM WALL then remove the lid) on the right hand side of the alloy centre channel at the top. It has two wires connected to the switch and in the centre there is a small black button. Press it firmly and it will heat up again. If this keeps tripping then the air duct could be blocked with fluff. This is my next task as mine now trips more frequently so will post back here with instructions.
Update 12/10/16 - problem returned so dismantled top of air duct having removed the lid - tight torx screws - inside chamber was full of fluff. Removed and cleaned - all good now!.
Jan 04, 2013 | Miele WT 2780 Front Load Washer
Dear Appliance Expert, my 7 year old ASCO T701 dryer out of a sudden doesn't heat continuously anymore, The heat automatically shuts down after a while and the laudry comes out quite damp even after 90...
it is quite possible that the sensor on the side of the drum could be coated with gunk clean the two little bar looking things on the inside of the drum with rubbing alchol and let thourghly dry and ventilate before using. the sensor after time gets a coating of softner and soap and lint other wise it may be the element or the board but try cleaning the sensor before going any further
Mar 05, 2011 | Kitchen Ranges
Quit heating
Hello there and thank you for choosing fixya
ok there are a few reasons why this happnes i will post them below for you
Investigate these five areas if your dryer is not heating up:
Proper Voltage
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Jan 22, 2011 | Dryers
My whirlpool duet electric dryer needs several cycles to dry normal load of clothes, dryer is 6 yrs old. Is it the heating element or could it be something else?
Initial reaction is yes, probably.
Second guess would be the switch.
The switch tells the dryer what to do, and if the heating element is good, it will do it.
Test the switch quickly first, and if it checks out, look at the element.
Oct 05, 2009 | Whirlpool Duet 7.0 Cu. Ft. Capacity Plus...
5 Year old Kenmore Elite Electric Dryer will not heat.
limit switch either the one on the heating element or the one in the air duct they are easy to check if u know how to use a meter they should read continuity when they are cold and open up at a certain temp
Aug 24, 2009 | Kenmore Dryers
Maytag Dyer model # MDE9700AYW wont heat it blows cold air
Ohm out the thermal fuse, if it is ok, then you can ohm out the heating element, be sure to visually check the element as well becqause it could just be shorted out internally giving you a reading, but first and foremost check your voltages be sure you are getting 240 across the outer plug spades and 120 volts from left to common and right to common, unplug this thing before you get into the element area or you could end up with a smokin fro !
Apr 07, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag PYE3300AYW Elec Dryer Runs, But No Heat
hello kellygubser,
If you are sure the thermal switch is ok.. have you checked the high temp ( bi metal snap switch) too? Here is a link to the wiring diagram of your dryer. You can see that there are a few other temp switches in circuit of the heating element that would disble it.. Hope this helps
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Jan 06, 2009 | Maytag PYE2300AY Electric Dryer
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Dryer runs for minutes then stops timer keeps going and going and .....
remove the vent on the dryer that goes to the outside start the dryer if it continues to ru n and not cut off you have a venting problem of the house
if it cuts off after 5 mins with the vent off you have a motor that is going bad
Jun 11, 2008 | GE DBXR463EBWW Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
156 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
