Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Back firing, load engine noise, engine skip - Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
  • 97 Answers
Could use more info but here are some things u can check--Plug wire grounding to block, old spark plug--check head bolts for correct torque--carb adjustment or jet plugged-governor linkage not hooked up or improper adjustment of governor--if these are good then it could be internal--bad valves and valve adjustment--timing gears
Posted on Jul 19, 2009
Check engine light report: cylinder 2 mis-fire, engine skipping, hesitant acceleration,
Use a different fuel station. First run the fuel tank low before refilling elsewhere.
Apr 28, 2017 | 2003 Buick Rendezvous
Have a 95 ford thunder bird at idle the engine has aalmost like a skipping vibration what could this be pretty sure it's firing on all 8
It sounds like a engine ignition misfire to me, have the plugs and plug wires been replaced? If not replace them taking care to route the plug wires exactly as the factory did, replace any broken loom holders for the plug wires, this is very important.
Sep 03, 2012 | Ford Cars & Trucks
Ecu for a 1995 f150 but motor is 1993 302 5.0 manual transmission
Yes the ECU should not affect the systems different firing order. If you want the correct ECU go here to purchase one.
Sep 03, 2012 | Cars & Trucks
Engine seemed to skip at about 70 mph and service engine light came on. Then seemed to skip several more times at different speeds. Ran fine. Just continued to skip as we drove.
hi the engine is not skipping the problem is the engine is miss firing
that is caused by a bad .spark plug or -wires-or coil pack - when was the last time the
car had a tune up . check spark plug connections
Jun 12, 2011 | 2005 Nissan Altima
Engine runs extremely rough, seems to be fuel related, new fuel pump & filter installed, pressure good, run 2 bottles of injector cleaner through. Can't get to stay running under load. 1998, chev....
Have you changed the plugs, if any are fouled out or if any are worn, it takes more to fire it under load and may be spark knocking because one of the plugs can't fire off all the gas and cause it to skip or idle rough.
Jan 18, 2010 | 1998 Chevrolet K1500
93 honda accord engine no fire cylinder 1
Check timing belt,sounds like belt may have skipped.
Jul 28, 2009 | 1993 Honda Accord
Engine Skipping, emmission issue?
check the catalytic converter first...it will make it sputter
Jul 05, 2008 | 2003 Ford F150 Regular Cab
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
765 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
