Question about Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc 650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower
I have a troy bilt mower with a briggs & stratton engine. How do I change the oil?
    President:
  • 1,776 Answers
There should be a drain plug on the underside of the mower deck. Raise that side of deck, remove the plug and drain the oil. Replace the plug and add new oil. Hope this helped.
Posted on Jul 19, 2009
    Problem Solver:
  • 15 Answers
I bought a new push mower this year.the manual tells you to pull the dip stick out and turn the mower upside down to drain the oil putting the dip stick tube on the low end. I'm not kidding.
Posted on Jul 17, 2012
  • andrianjeff Apr 01, 2013
    2012 6.75 190cc gold series 22inch blade craftsman-- I did exactly that-- were is the drain plug?
4 Suggested Answers
SOURCE: Troy-Bilt Briggs & Stratton 550 restarting
Troy, Unless you are using old fuel (it breaks down after 1 week) it sounds like you have a faulty spark plug. Replace this first, drain any old fuel and replace with fresh fuel (premium unleaded). A faulty plug will work one minute but then fail like you have described.
Posted on Oct 25, 2009
  • 404 Answers
SOURCE: where is the oil change plug
The plug is under the mower on the bottom of the engine. Make sure you take the spark plug wire off before you work, remove the blade (it needs sharpening anyway right?) and then tilt the mower on its side WITH THE CARBURETOR UP. position an aluminum cake tin under the mower so that once you remove the oil plug using a 3/8" ratchet you can set the mower back down over the cake tin and it will catch the oil. Don't forget to put the plug back in =-)
Posted on Jun 04, 2010
  • 152 Answers
SOURCE: LOOKING FOR A MANUAL FOR A 21" CUT SELF PROPELLED
try putting your serial number and model number here. http://www.troybilt.ca/troybilt/troybilt_manual_search.asp
Posted on Aug 08, 2010
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Where is drain plug for oil on Troy bilt Tb230
It does not have a drain plug. You can remove the dip stick and tilt the mower to pour out the oil, or you can use one of those hand pump syphon units to pump it out.
Mar 23, 2012 | Briggs & Stratton Lawn-Boy Insight Series...
Gas tank leak
The gas tank would go with the engine. Find the engine number (Briggs & Stratton?, Kohler? ) You can order it online from Briggs & Stratton parts, or like Jack's small engine, or your local mower parts supply. Common poblem with these plastic tanks.
Jul 19, 2010 | Troy-Bilt Pony Garden Tiller
Where is the oil change plug
Jun 04, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Where is the drain plug to drain and change oil on a standard push mower
It's under the mower on most Briggs & Stratton engines and others. It's about 2 or 3 inches from the shaft. It may be a bit hard to see because of being caked with grass. Use a putty knife to scrape it off.
May 10, 2010 | Garden
Tory bilt lawn tractor replaced with new battery
What most likely happened is the diaphram in the carberator has burst. It is a simple fix if you take your time, use reliable resources and be patient. The parts can be picked up at the local hardware store.
Mar 25, 2010 | Briggs & Stratton Garden
Oct 24, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Misplaced operation manual for Troy-Bilt Briggs & Stratton Super Tomahawk Chipper/Shredder 8 HP Can it be downloaded? What kind of oil does the chipper use?
Straight 30w NOT 10w-30
prefer air-cooled engine oil from mower dealers or some auto supply stores have air cooled engine oil.
Oct 07, 2009 | Troy-Bilt® Briggs and Stratton Chipper
Need a fuel tank for a Troy Bilt mower
You won't find the fuel tank on MTD's site because it is part of the engine. MTD makes the mower, Briggs and Stratton makes the engine. Get the model and type number off the engine and search Briggs and Stratton's site or post it here and I will tell you the part #. Dwain
May 21, 2009 | Troy Garden
Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
2,483 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
