Question about Garmin Nuvi 680 GPS Receiver
Touch screen not responsive. LCD screen OK.
Garmin Nuvi 680 touch screen not responsive. LCD screen OK.
  • 4 Answers
Try to calibrate the touch screen .
If not send it to a repair centre they will fix the touch screen for you.
Try here www.satnavrepairservice.com
Regards
Posted on Aug 04, 2010
My Garmin has lost much of its "touch response" especially the lower lines where the Spell, go-back arrow, and go-down to next options are. Basically useless for all but Map viewing
Take you GPS to a repair service and get recalibrated or repaired the touch-screen. Or do it yourself?
https://support.garmin.com/support/searchSupport/case.faces?caseId={31446910-c3a3-11e4-cd20-000000000000}
Garmin Nuvi LCD Screen Removal Replacement Pt 7 Garmin Nuvi 2460 LCD Screen Replacement Disassembly instructions
have cracked Gps screen where can find replacement screen
Garmin digitizer replacement GPS
Look for more tips with Google: searching for
REPAIR TOUCHSCREEN GARMIN
Sep 22, 2015 | Garmin GPS
Garmin Nuvi 610- working perfectly then sudden crackling and now loss of sound/or at best crackly and intermiitent sound- but map/navigation and on-screen directions fine
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Sep 24, 2010 | Garmin Nuvi 610 GPS Receiver
Garmin Nuvi 680 no longer has any audio
Hello :
It's a common software problem with your device . To correct the problem I recommend you to reset it .
Here is how to reset your device :
1:Turn the Nuvi on.
2:Touch the tools icon on the main screen. The tools icon is represented by a wrench surrounded by a blue circle.
3:Touch the "Settings" icon which appears as a wrench.
4:Push the "Restore" button at the bottom of the screen. A confirmation message will appear asking to confirm restoring the Nuvi to factory settings. Push yes to restore the factory settings
Try this for hard reset .
Turn off Garmin device. Press down on bottom right corner of the touchscreen [ Don't let go ] , and then power on the GPS unit. You should be prompted whether do you really want to erase all user data, or asked if do you really want to start up in maintenance mode. Press “Yes” to reset (warning: all data will be erased and lost, so backup before proceeding) or enter maintenance mode.
PLEASE DON'T FORGET TO RATE !
Apr 15, 2010 | Garmin Nuvi 680 GPS Receiver
Touch screen not responsive Garmin 680
The cable to the touch sensitive part of the screen may have come loose (easily happens if knocked).
Try taking the unit apart (with care and the right type of screwdriver) and reseating the connector cable.
Once you've done this you may need to recalibrate the screen. Holding the power switch down will get you to the reboot / recalibrate screen.
But of course this will probably invalidate your warranty so beware.
Nov 04, 2009 | Garmin Nuvi 680 GPS Receiver
I have a Garmin Nuvi 680 and the touch screen stoped working.
The touchscreen needs to be replaced. Please see this link which explains why this happens:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Oct 20, 2009 | Garmin Nuvi 680 GPS Receiver
Garmin Nuvi 680 Touch Screen "touch" works intermittently
Recalibration has nothing to do with repairing this problem. If the touchscreen is non-responsive, how are you going to recalibrate it when it doesn't recognize the key presses?
The problem is caused by a defective touchscreen. SHARP substitued a different touchscreen into the 6xx series that fails even when the glass isn't damaged. The problem is caused by a defect in the manufacturing process where the touchscreen connections becomes detached from the tail that plugs into the board.
The touchscreen connections between the screen and the tail are made from conductive ink that can fracture, most likely caused when pressing on the screen over time.
These defective screens can be identified by a white tail cap at the end of the tail, whereas the original touchscreens have a maroon tail cap. The original touchscreens will only fail if the glass has been broken.
I only use the original touchscreens for all of my repairs.
- Jim
Oct 05, 2009 | Garmin Nuvi 680 GPS Receiver
Garmin Nuvi 650 broken touch screen
Less than one minute on Google: http://www.palmdr.com/cart/garmin-nuvi-650-660-670-680-complete-screen-p-168.html
Jan 02, 2018 | GPS
Garmin Nuvi 680 GPS Receiver Logo
555 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
