Question about Kenmore Elite HE4 Electric Dryer
I have a kenmore elite smartheat quietpak 9 model# 110-85091400. When you hit start it just beeps and will not run
I know it might be coming too late for you...but at least it may help others. I`ve just fixed the problem myself. First you didnt mention if the inside light turns on n off with the closing of door. Mine was burned so I replaced it to find that it was always on. so I figured it had to be the door switch. I called Sears n the part was more expensive there $52 cad but they had it in stock.So I unplugged the Dryer n turned the breaker off. ( as an amateur , one should b xtra careful...)unscrewed the 3 back screws, the few screws holding the pieces of metal under the top enamel cover, gently pulled up the control panel enough so I could reach the plastic connector that links the interior wires to the door switch n pulled the defective part out n gently inserted the new one in as I didnt take the whole front apart I did need a hanger wire to grab the wire from the top. Obviously u could take the front of the dryer off but I could easily see the wires n picked it up on the first try,the whole process took me 10 min max n it works. Oh yes! I did remove the very bottom front part ( 2 screws) only to find a manual in there it will tell u how to test the dryer n get a error code back ( in a nut shell u press more time less time more time less time within 5 seconds while the dryer is off (no lights) n in the manual it gives u the meaning of error code...Good luck to all!
Posted on Aug 11, 2009
Remove the lint screen and unscrew the lint filter on the inside of the drum. Vacuum out the lint that is probably accumulated on the inside of the machine. I had the same problem and just fixed it by doing this
Posted on Jan 03, 2012
My Kenmore Elite Smartheat Quietpak 9 HE 5 has been making loud squealing noises while it is running...there still is heat coming out but I am afraid it is going to seize up or burn up motor... no smell...
Hello and Welcome to FixYa
When the dryer makes sequeaking sound, usually it is the belt that is either worn out or has gone bad, however it is also recommended that the idler pulley be checked and replaced if that is also bad along with the belt. You can check this video to replace the belt:
Nov 28, 2010 | Kenmore Dryers
Kenmore Elite Smartheat Quietpak 9 Dryer won't turn on.....as if there is no power. After being unplugged for a while, it will run one cycle.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite Smartheat Quiet Pak 9 won't start. Light turns on and off inside drum when door opens/closes, but no lights come on on the outside display.
My Kenmore Elite dryer keeps beeping..just going through the end of cycle alarm-high,low,off...anyone have any suggestions?
May 30, 2010 | Kenmore Elite HE4 Electric Dryer
My Kenmore Elite Smartheat Quietpak 4 will not start. F70 code
leave door open and press the rubber botton inside, \ I just hooked up mine and it did same thing, i pushed botton light went out, so this told me the door wasnt closing correctly, you have to push hard on door first couple times. hope this helps you.
dave
Feb 09, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite smartheat quietpak 9 model#110.85872401, it will not heat up just cold air. the air lint filter is clean.
make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Nov 07, 2009 | Kenmore Elite HE4 Electric Dryer
Control locked
Mine has an "auto dry" button. It says underneath, "Press & hold 3 seconds..." to unlock control. I did it, it worked.
Feb 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
813 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
