Question about Estate Refrigerators
Ice maker make ice but leaks water into ice bin.Cubes freeze together and cannot be dispensed
  • 714 Answers
You can go to RepairClinic.com they can give you repair help and parts if needed! Goodluck!
Posted on Jul 18, 2009
Ice maker crushes ice but wont dispense Crushed ice
Good Afternoon Friend,
I understand that the ice maker in your Frigidaire refrigerator, model# FRS23H7CS, is crushing your ice, but will not dispense the crushed ice. It sounds like the dispenser is possibly jammed. Follow the following steps for a possible resolution:
    1)The ice has melted and frozen around the auger due to infrequent use, temperature fluctuations, and/or power outages. Remove the ice container, thaw, and empty the contents. Clean the container, wipe dry, and replace it in the proper position. When new ice is made, dispenser should operate.
    2)Ice cubes are jammed between the ice maker and the back of ice container. Remove the ice cubes that are jamming the dispenser.
    3)Ice cubes could be frozen together. Use the dispenser often so that cubes do not freeze together.
    4)The ice cubes are hollow or smaller than normal. The ice & water filter cartridge could be clogged. Replace the filter cartridge. Dispensing system operates best at 20 - 100 psi water pressure. Well water pressures should fall within this range.
    If the above does not work, I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Turn the power back on and try dispensing crushed ice. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully.
    -Best Regards-
    WP
Jun 20, 2014 | Frigidaire FRS23H7CS Side by Side...
Ice maker
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
other ice maker related issues and solutions:---
Ice maker dispensing ice with black or white plastic pieces in ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-ice-with-black-or.html
After replacing ice maker assembly, ice is not getting made?
http://alltypesofpartsreplacing.blogspot.com/2011/10/after-replacing-ice-maker-assembly-ice.html
Ice maker is leaking water and causing the ice to freeze?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-leaking-water-and-causing.html
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
Refrigerator ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/refrigerator-ice-maker-stopped-making.html
Ice maker leaks water into ice bin causing a glob of ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaks-water-into-ice-bin.html
Amana Refrigerator leaking water from ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/amana-refrigerator-leaking-water-from.html
Ice maker leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaking.html
Ice maker is dumping the ice cubes out before frozen solid.
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-dumping-ice-cubes-out.html
Water overflowing ice maker?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflowing-ice-maker.html
Ice cube is getting stuck up hard in ice maker
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-cube-is-getting-stuck-up-hard-in.html
Icemaker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/icemaker-quit-working.html
Quit making ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/quit-making-ice.html
Water leaking into ice tray, frozen glob of ice
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-leaking-into-ice-tray-frozen-glob.html
Not making ice, and water leaking in freezer?
http://alltypesofpartsreplacing.blogspot.com/2011/10/not-making-ice-and-water-leaking-in.html
The ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice_20.html
Ice maker not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-making-ice.html
Ice maker quit working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-quit-working.html
Ice maker dispensing black pieces of plastic in the ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-dispensing-black-pieces-of.html
Replaced Ice maker but its still not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/replaced-ice-maker-but-its-still-not.html
Ice maker leaked creating an ice block?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-leaked-creating-ice-block.html
Ice tray leaked?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-tray-leaked.html
Ice maker stopped functioning?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-functioning.html
Ice maker stop working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stop-working.html
Ice maker failed
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-failed.html
Old ice maker stopped working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-stopped-working.html
Old ice maker started leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/old-ice-maker-started-leaking.html
Ice maker not working?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-not-working.html
Ice maker overfills and cause water to flow into ice dispenser and freezes?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-overfills-and-cause-water-to.html
Ice maker didn't make ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-didnt-make-ice.html
Ice maker was leaking?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking.html
Ice maker was leaking after it filled up with water?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-was-leaking-after-it-filled.html
These will help.
Thanks,.
Dec 21, 2012 | LG LFX25976ST - 3-Door French Door...
Excess water delivered to ice maker
That will depend on type of ice maker and model number of refrigerator. At times the water control valve will stick because of age or just leaking while off like a dripping faucet. Can you find model number of your whirlpool? I do have some repair manuals for ice makers if they are not the electronic type. Sea Breeze
May 22, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice in the bin on subzero 632 freezer is in clumps
if the ice maker leaking it's easy to replace, or may be just a water supply tube has been moved to the side
Oct 03, 2009 | Sub-Zero 632 / S
LG ice maker only making two ice cubes at a time
Colenoid in the ice dispenser may be clogged or have a small amount of trash in it. Is there a filter on before the fridge (just after the ice maker shutoff)?
Mar 21, 2009 | LG LRSC26910 Side by Side Refrigerator
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice Maker Overflowing
i would recommend changing the water valves as they may be sticking or leaking now you can take the icemaker loose get a small baby bottle short the terminals to cycle water fill catch it with the bottle and see how much water it dumps should be about 4 ounces if the valve leaks will over fill the ice maker over a period of time say the valve is leaking a few drops at a time and the bail arm has the icemaker shut off because its touching ice in the bin but the water just keeps dripping down the fill tube till it runs over did you replace the whole icemaker or just the motor module
Jan 01, 2008 | Maytag MSD2434GE Side by Side Refrigerator
My ice freezes together!
Do you mean the ice cubes are too large to be individual cubes and come out as a lump? The water is filled by a timed fill so if the fill solenoid stays open a little and drips water into the cube tray it will have more water than normal. I guess I'm not sure if you mean the ice cubes are stuck together in the tray or are they sticking together in the holding bin area?
Jan 30, 2007 | Kenmore 74172 / 74174 / 74179 Top Freezer...
Refrigerators Logo
111 people viewed this question
Top Estate Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Audie Bogus
Audie Bogus
Level 1 Expert
Are you an Estate Refrigerator Expert? Answer questions, earn points and help others
