Question about Palm Treo 650 Handheld
When battery is installed the screen shows 4 even space bars...the top one red, then green, blue and white with the word "bootload v 0.24" in the red bar and "SD" in the green bar and its frozen there. I've tried soft reset, system reset, and hard reset...nothing works.
Posted on Aug 14, 2009
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Dear All i would be glad if some one can fix
sounds like its stuck on the bootloader did you try updating/flashing the phone? the rom is currupted it must be repaired by someone that knows or sent it in for warrenty!
Aug 29, 2009 | HTC TyTN Smartphone
My HTC TYTN11 shows red green white etc colors when switched on
the tricolor screen means your device is on bootloader mode.
this mode is for reflashing your device OS.
if you entered this mode accidentally, you might try to release your device's camera button. Since the factory setting to enter bootloader is reset button+camera button from standby mode.
try to get battery out and release the camera button. many times happens that this button get stuck inside, because it's not a button you use many time and it get fully of dust.
Aug 29, 2009 | HTC TyTN II Smartphone
I cant go beyond the red green blue white screem
Everytime I turn on my phone its like that.
Nothing's wrong with your phone dear.
If you think Im not sure well I have the same phone and I've had it for a year. So Im sure nothings wrong. As long as its operating fine its ok. Believe me.
Just a little check...
Can you still use the camara?
Can you beam a photo to another phone using bluetooth? If yes, than NOTHING is wrong.
If you have anymore questions I'll be glad to help. Just comment back and I'll try to answer you ASAP.
Good Luck!
Aug 07, 2009 | HTC TYTN GSM Phone
Frozen screen with 4 band colors
Your phone is stuck in bootloader mode, it seems that you may need to reinstall your phone OS on your phone.
Go to the HTC site and download your phone's OS files/installer:
http://www.htc.com/us/SupportDownload.aspx?p_id=67&cat=2&dl_id=68
Follow the installer's instructions after you've downloaded the needed file.
Jul 19, 2009 | HTC Tilt 8900 Smartphone
First & Third space in GE TPL412RP are hot, second &fourth not
This is not 3 phase power...you have two legs of 120 ...the red wire? This leg is not a voltage source therefore that wire is not going to fire up that lug ...you only need 3 wires to make this circuit and a neutral is a redundant leg for this box
Jun 28, 2009 | General Electric G.E. - INDUSTRIAL SYSTEMS...
Error 0.14
Finally found this solution! It is a connection issue at the bottom of the phone where you would plug in the cable to hotsync your phone.
Put in your hotsync cable and wiggle it around really good and it will fix the issue. Do this with the battery out and then pop it in until you have fixed the issue. Took me a few tries as I was worried about how hard to do it, but no problem!
Nov 18, 2008 | Palm Treo 700p Smartphone
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEARED ON MY SCREEN???
hey, i had the same problem and i fixed it. i took the battery out and saw the 4 golden tabs behind the battery. there was two tabs that u could pull out. i lightly pulled them out a little bit. the problem was that the tabs wouldnt hit the battery to charge it. thats why it put the tri colored screen on the front. also my charger fit into the charging hole in the phone, but it had to be moved around to much that it did not fit exactly. I have been rough with the charger so it moved the inside of my phone around. i put the charger in the phone and moved it around gently around untill the light lit up on the front at the top by the word at&t. after it was completly charged, i turned it on and it worked perfectly. i hope this helps in whoever may have this problem because i know it sucks!
Thanks
Aug 08, 2008 | HTC TYTN GSM Phone
RED, GREEN, BLUE AND WHITE HORIZONTAL BARS APPEAR ON THE SCREEN...
Remove battery , let sit for 2 miniutes . Re install battery , in proper position , hold on button for a few seconds and this should work ...
Jun 11, 2017 | HTC TYTN GSM Phone
Nada
I would go to the AT&T support site or HTC. from there you can download the firmware update file wich can try to recover the unit for you. from the sounds of it, it may be stuck in bootloader mode. either way, its likely you will loose your data and programs.
Dec 06, 2007 | Cingular Wireless Cingular 8525 Smartphone
Palm Treo 650 Handheld Logo
305 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
