Question about Ruud Matching Split Air Conditioner
Ruud 10 seer fan outside made low grinding noise then stopped working.
  • 614 Answers
Bearing bad in motro or possible bad capacitor. Hard to say unless you know how check capacitor and fan motor. Price on cap replacement about 150 Fan motor abot 250 to 300 with new cap. Ask for free estimate before you commit. Russ
Posted on Jul 18, 2009
A/c on 3 ton 13 seer ruud heat pump not cooling
you have condenser issue. check at outside unit for 240 volts to contactor and 24 volts to contactor coil.
May 11, 2013 | Ruud 3 Ton Split System Heat Pump
Ruud achiever 10 seer breaker keeps tripping
Sounds like a short to ground problem with either the motor windings shorting to ground or a high voltage wire shorting.
Nov 25, 2012 | Ruud Matching Split Air Conditioner
I have a Ruud 10 Seer airconditioning unit. The blower inside starts up but the fan outside does not. Any suggestions?
Look at the t sat wires if thy are good then go out side and take off the cover for the power you shod see where the power go in at in the middle of that piec you can push it in if it comes on the replace it
Aug 14, 2012 | Ruud Matching Split Air Conditioner
Ruud achiever seer 10 air condioner not blowing cool air
need more info, touch the copper lines going into the unit do u feel any flow? Go outside do you see any fans turning? number of things you can do. Get back to me
Aug 12, 2011 | Heating & Cooling
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
Ruud achiever 10 seer air conditioner
It sounds like your condenser fan motor may be locked up or the capacitor that helps give the condenser fan motor a kick to get it started may be defective. Try turning your system on and using a long screwdriver try to push the fan blade on the condenser fan motor to see if it will run normally if you give it the starting boost it needs.If it does run at full speed and doesn't over heat or start and then slow down then you probably only need to replace a simple 10-12$ capacitor. If it barely turns, makes an odd humming sound or overheats etc. then you will have to replace the condenser fan motor. This is assuming that the outdoor condenser has the 220v supplied and the 24v supplied to the compressor relay, that the compressor relay is engaged and suppling 220v to the condenser fan motor.
May 28, 2008 | Ruud Matching Split Air Conditioner
Ruud Matching Split Air Conditioner Logo
160 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
