Question about Kenmore 20.6 cu. ft. Upright Freezer 24092
My upright freezer only goes down to 31 degrees, I have a refill adapter and it shows that R-12 is 52 psi, R-22 is 28 psi, and R-502 is 20 psi. Im not sure what I have in the freezer, i figured you could help. I think my problem is i don't have enough coolant, what do you think?
  • Kenmore Master
  • 1,606 Answers
Refrigerators dont loose refrigerant (extremely rare) for the past 20 years .(except Amana ) I think your problem is elsewhere such as : dirty coils , frost on the rear wall (behind panel) indicating a defrost problem , compressor fan or freezer fan not working .
Posted on Jul 19, 2009
I have a gram freezer, I cleaned motor on condenser fan, and now it works in the laid down position but not upright?
you should never lay freezers of fridges down as it puts the refrigerant gas in the wrong place. The compressor is a pump, and it pressurises the returning gas in the condenser and turns it into a liquid, this is the 'high pressure side'. The liquid is pumped to the evaporator inside the unit, where there is spare air volume, and the liquid turns into a gas and goes very cold. This is the low pressure side. Your refrigerant liquid is in both places.
Turn it off and leave it upright for 24 hours to settle. If that doesn't fix it, you will need an engineer to empty the gas by sucking it out and then refilling it with new gas.
Dec 17, 2015 | Freezers
Kenmore upright freezer. Ice cream soft. Food is cold. HELP!
Ice cream has to be colder than 0 degrees C /32 degrees F. You need a cheap thermometer If your Ice maker Ice is not sweating in the bin, -10 degrees F ice stops sweating. you need not to sweat the freezer untill your cheap freezer thermometer can be compared to -10 degrees F
Nov 29, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Older Gibsonl upright freezer not cold
dear sir
please make sure first your freezer is well clean if it is already clean then contect to maintenance personell for refilling the gas.
hope answer the question.
thank you.
Jul 05, 2010 | Frigidaire Freezers
Freezer not cold enough
the dryer is already sock ,, you need to change it and refill the gas
Jan 24, 2010 | Freezers
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer due to brown out then power restored now low temp alarm
The light should reset itself when the freezer gets to less then 18 degrees. If it is still above 18 degrees it will stay on. Now if it is cooler then 18 degrees then unplug the unit for 1 minute and plug it back in once you are sure that it is below 18 degrees. But do not rule out the thermostat. It could have blown out when the brownout happened. To test it jump the wires together and see if the freezer comes on and goes off
Feb 14, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Kenmore 20.6 cu. ft. Upright Freezer 24092 Logo
204 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
