Question about Kogi l4ax 14.1" Flat Panel LCD Monitor
I need a power cable source. - Kogi l4ax 14.1" Flat Panel LCD Monitor
E-Bay
Posted on Jul 23, 2009
    President:
  • 1,179 Answers
Try www.cables2go.com. They sell about every replacement power cable known to man. Hope this helps.
Posted on Jul 19, 2009
Have colored lines at bottom of tv
Hello!
First: disconnect any signal source from your TV, including cable. Unplug TV off the wall or power strip. Let it sit for a minute or two. Plug power back in. TV might turn on itself, might not. Depends on configuration. Turn it on manually, using set's "power" button. Observe the behavior. Lines? TV need repair! Not an armature job. Lines gone? start to connect signal sources back, starting with cable. Observe the picture. No lines? Proceed to the next source: DVD player, and so on. At some point lines might return. Make note, what source causes the problem. Then, you may know what to do next.
good luck,
Alex.
Jan 10, 2012 | Panasonic TCP46C2 46 in Plasma TV
My PC power supply crashed, burnt resistors, Powerman IW-P250A3-1 20 pin plug to motherboard, bought new power source, but the old power source had a white cable to the 20 pin plug which was -5vdc 0.3amp....
For your system to boot up properly, you need an identical power supply for your system. Most likely the reason why your system won't boot up right now is because you purchased a different power supply and it is lacking something(which is the other pin).
Regards
Sep 14, 2011 | Computers & Internet
My printer won't turn on
Hi
Either the power source has issues or the power jack on printer has gone bad or printer's main board has issues.
Verify that the electrical connections and outlet are functioning:-
Unplug the power cable or power module from the electrical outlet.Unplug the power cable or power module cable from any power strips or surge suppressors.If the product uses a power module with a detachable power cord, unplug the cord from the power module, and then plug it back into the power module.Unplug the power cable or power module from the back of the product.Wait at least 30 seconds, and then plug in the power cable or power module into the electrical outlet.Plug the power cable or power module back into the product.Turn the product on.
If this doesnt help, take the printer to another room and plug it in another power source.
If this doesnt help, use a multimeter to check if adapter is giving out right voltage.
If adapter and power source are fine, then your printer has a hardware issue and needs to be repaired by Canon.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Canon PIXMA MP780 All-In-One InkJet...
What kind of power source does thee del3331-33ub use show me picture 0f power source cable
Hello, this device self feeds from the USB cable, doesn't need any kind of power cable.
Thanks
Jan 11, 2011 | ID Tech DEL3331-33UB
What chords are needed for the hp officejet 7110 all in one. The chord to the electrical outlet, to the internet, the computer, the fax, and anything else I might need. They got lost in moving
I must warn you that this printer has an external power source - if you have lost it you must order it directly at HP, never use some cheap replacements bought at the store, only the official part. The power cable that plugs in the power source is your average pc power cable.
After that you will need a LAN cable (for the internet) an phone cable (for the fax) and a USB cable (for the connection to the pc). All these cables can be very cheaply purchased even at
 WalMart for $5 each.
Aug 17, 2010 | HP OfficeJet 7110 All-In-One Thermal...
I have a cable box connectin and cannot choose HDMI as a source. I had HDMI as the source for about two years and then something must have changed. I have verified the HDMI cable is not the problem. Page...
The manual is telling you that your "source", whatever you are connecting to a particular HDMI port, needs to be turned-on in order for the TV to detect it. Make sure that the HDMI cable plugged into the correct HDMI port for each device (TV & cable box) and that the cable box is on. Does the cable box HDMI port need to be selected in order for it to be functional or is it on all of the time? Check your cable box instruction manual for details on the proper way to enable (turn-on) or disable the various outputs if needed.
Let me know if you need additional info.
Feb 26, 2010 | Samsung HL-S5086W 50" HDTV
Printer will not print hp error messsage oxc19a0024 removed all cartridges pupluged as recommended
OKSolution 1:
  1. Turn off power and unplug from power source.
  2. Open right side of printer.
  3. Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
  4. Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
  5. Unplug power source.
  6. Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
  7. Plug in power source and turn printer on.
Solution 2:
  2. Open right side of printer (looking at the front).
  3. Disconect,by pulling gently, the flat ribbon cable off the main circuit board that is the smaller of the two.
  4. Plug in power source and turn printer on. Wait till you hear no more movement from inside from unit booting up.
  5. Press both cancel and power button at the same time.
  6. Message on printer screen will be, "Enter Special Key Combo".
  7. Push keys; Left-Ok-Right.
  8. When printer screen changes, scan through and look for "System Menu" and push "Ok"
  9. Scan agan and look for "Clean Derivative" and push "Ok". Wait for 1 minute.
  10. Scan agan and look for "Clean Firms" and push "Ok". Wait for 1 minute.
  11. Press "Cancel" 4 times
  12. Turn off power and unplug from power source. Wait for 2 minutes.
  13. Reconect the flat ribbon cable by aligning and carefully pushing into the conector on the main circuit board.
  14. Plug in power source,and turn on power.
  15. When printer boots up, answer the questions on the printer screen for your area.
  16. The printer will cycle the ink from the cartridges to the print head and back.
Pineworks
Oct 01, 2009 | HP Photosmart C5180 All-In-One InkJet...
Faulty tevion lcd 32
  1. Check the cables and connections: Make sure that cable connections are securely fastened to the connectors and try reseating the connectors. If connecting a device using component cables, make sure all three color-coded cables are connected correctly into the corresponding connectors. Check the condition and length of the cables. Cables that are longer than 3 meters (10 feet), become more susceptible to promoting signal degradation (small dots "sparkling" on the screen and image ghosting). Cables that have been bent or pinched may also cause picture quality problems. Replace the cable or try a different cable type.
  2. Press the CH button to display a different channel. Picture quality problems on a single channel or on all channels may be caused by the TV station signal (antenna) or the cable signal source.
  3. Make sure that the image quality issue is not coming from your source signal. For example: if the image quality issues occur while viewing TV, switch the source to a DVD player to see if the image quality problems go away. If selecting a different input source (using the remote control) causes the problem to go away, troubleshoot the source device causing the problem - adjust aerial antennas, call the cable company for assistance, and . If a picture quality problem occurs on all sources, the TV or its settings may be the cause of the problem.
  4. Open OSD to adjust the picture: Press the Menu button to open the OSD. Select the Picture menu and adjust the image as needed. If you cannot adjust the TV to fix the problem, reset the settings from the OSD to see if the problem goes away.
  5. Unplug the TV from its power source. With the power cord unplugged, press and hold the power button for five seconds. Turn on the TV. If the image quality problems still exists across all types of signal sources, the TV should be serviced.
May 25, 2008 | Televison & Video
Pt-47wxc43g tv
No ,
Fisrt I need more info, what source of input or you using, video 1, 2 etc... or is it your calbe connection input.
If you or using av cable's, witch I would, connected to source input 1 with video in and two audio in and go to the ptv menue and put in on source input 1.
This should work if it doesn't then you may have cabling problem, ptv problem or cable box problem.
First start by suspecting cable problem, swap the cable to see if you get picture, if not try a differenct source of input a dvd, it should solve your problem
Regards
What About Bob
Timmins, Ontario
Home of Shania Twain.
Mar 08, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Kogi l4ax 14.1" Flat Panel LCD Monitor Logo
73 people viewed this question
Top Kogi Computers & Internet Experts
Laxman Bisht
Laxman Bisht
William Miller
William Miller
Are you a Kogi Computer and Internet Expert? Answer questions, earn points and help others
