Technics HD560 Losing Sound
My technics hifi will play when you first turn it on, whether it be radio or cd, however after a couple of minutes the sounds disappears, you have to remove the mains power, turn back on for the sound to reappear, however after a couple of minutes the same thing happens - have visually checked the boards of the amp and see nothing obvious, have resoldered all joints and still the same
  • 979 Answers
Hello sir, there are several things you should check for, first the impedance of the amp and speakers, do they match 8ohms to 8ohms, two the amplifiers heat sink is it sufficient? or the amp. may need an extra cooling fan. third the main amplifier is the culprit. check each one and let me know if there is progress. thanks
Posted on Jul 21, 2009
Ineed remote for technics hifi model nos slhd60
The only place to try, would be Andrews Electronics, in Valencia, CA. It may be discontinued if it's older than about 2 years. Happy hunting.
Oct 13, 2014 | Technics SL-1210 Turntable
Hi i have technics Compact 5 Disc Cd Changer SL-EH790
Carousel-type changers such as yours are prone to eventual failure.
Mar 23, 2014 | Technics Audio Players & Recorders
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
Sep 26, 2012 | Technics SL-1200 Turntable
Hi my technics hifi is playing up, it turns on but the stereo sound processor will not come on.this needs to work for the hifi to work can you help
hi mate, the sound processer has packed up, mines done exactly the same thing, i've taken it in to a panasonic technics specialist and the verdict is just that. i've confirmed it by swapping the sound processor with one off a friends stereo and mine came back to life. Hope that helps mate.
Feb 21, 2010 | Technics SC-DV290 System
I have a technics SU-CH7 mini hifi. There is now
Hello I have exactly the same problem did you have an answer since your question.
We think that the problem is power supplier...
Best regards,
Patrick.
Nov 22, 2009 | Technics Audio Players & Recorders
Technics amplifier switches off
1-keep good ventillation around and do not block any ventillation holes with any thing.
2-check your connection cable in good condition no touching of inner conductor with any chasis.
3-check your loudspeakers and apply them to the system one by one until you find the bad one(which make the problem if it is bad)
Jul 05, 2009 | Audio Players & Recorders
Technics sa dv280, input selection
You can try starting the music on your computer before trying to change the input on the receiver, maybe it needs to recognize some input before it will change if this doesn't help double check your connections & settings ?
Jun 25, 2009 | Audio Players & Recorders
TECHNICS SC-EH750-CD KEEPS SKIPPING
replace travers assy ,because spindle motor is faulty. If you can get spindle only it will be chiper solution for you.
Nov 10, 2007 | Technics SC-EH780 CD Shelf System
Error message when playing any DVD in Hi-fi
i once had a panasonic dvd player which displayed the same code H02 and used the same drive mechanism as your player. this turned out to be a worn spindle motor and once replaced, all worked fine. you may well have the same fault. hope this helps?
Feb 28, 2007 | Technics SCHD560 CD Shelf System
Technics cd hi-fi
hi bobro, when burning the cds, make sure that you are burning it as an audio cd, as this player does not support mp3 formats, just normal audio cds... hope this helps!
Feb 11, 2007 | Technics SCEH790 CD Shelf System
214 people viewed this question
 Grubhead
Grubhead
