Question about Cuisinart DCC-1200 Coffee Maker
Cuisinart DDC-2200 coffee maker problem: Sometimes the unit brews less cups than cups of water put into it. Then, after while, you get a brew that give 2 or 3 cups more than what was put into it. The unit seems to be holding water somewhere and then releases it when it wants to.
I have a ddc2200. where is the fiter
Posted on Sep 06, 2010
Clean the pot by brewing a full pot of undiluted vinegar, then rinsing it by brewing 2 full pots of water through it. Also, change the charcoal filter on a regular basis. We clean the pot this way every month and replace the filter every 2 months.
Posted on Jul 29, 2009
We've had a Cuisinart DCC-2000 coffee maker for less than a year: 1) it stops brewing about halfway through the brewing cycle (with plenty of water still in the reservoir, and 2) the "Clean" light
This problem is caused by a clogged water filter in the unit.
Unplug the coffee maker.
Open the top panel where you normally pour in the water and set the coffee filter.
Gently pull up on the tap that sticks up in the back left corner of the open top. This will free a long plastic part that has a compartment at the bottom that contains a filter filled with charcoal.
Unsnap the small compartment that holds the filter and clean it gently under running water with light brushing.
If there is a lot of coffee build-up, the water chamber where you normally pour in fresh water needs to be cleaned out. Pour in a cup of water and invert the unit over a large sink pouring out the water through the opening you normally use to fill the unit.
Repeat this until you remove the coffee grounds.
Let the unit dry fully before plugging in to run again.
Sep 30, 2012 | Cuisinart DCC-1200 Coffee Maker
My machine doesn't brew - the water doesn't flow through: why?
i have a 12 cup programmable cuasinart coffee pot sometimes when i turn it on it will brew right away and sometimes it takes forever to brew. what could be the problem?
Nov 13, 2010 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart grind and brew--water does not come down
If the water is not coming out of the filter basket, and is instead leaking over the edges, then replace the brew basket.
If there is no water at all, call Cuisinart - those coffee makers have a 3-year warranty.
Feb 25, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
My cuisinart cod 4000 doesn't use the last 2 cups of water in the reservoir when brewing. Any ideas on what would cause this and how to fix it? It is less than 1 year old.
I would go ahead and clean the unit with vinegar and water - I would use 2 cups vinegar and 2 cups water, although the manual suggests 1/3 part to 2/3. Just brew the vinegar/water like it was normal coffee. Don't forget to take out the charcoal water filter, or else it will get soaked with vinegar. Also, make sure the 1-4 cup button is not pressed, if your variant of the model has a 1-4 cup setting. Good luck!
-Tha Mp3 Doctor
Incomplete brew
Sometimes you have to do the decalcification two or three times. Then, monthly after that.
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Jan 01, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart 14-cup coffee maker won't put out coffee
Clean it out with 1/3 caraffe worht of vinegar and 2/3 caraffe full of water - just brew the solution as if it were regular coffee - you may have to repeat this process up to 3 times.
-Tha Mp3 Doctor
Dec 21, 2008 | Cuisinart DCC-2200 14-Cup Coffee Maker
Cuisinart Grind & Brew not using all the water in the reservoir
I was having problems like this and then I read on a different string on this website that people have had success by flushing the system numerous times (sometimes up to six times) with vinegar. I took out the charcoal filter and flushed once with vinegar but only saw a small amount of improvement. I was out of vinegar so I used Lemishine mixed with water and it went from making one cup to making a full pot with one flush.
Jan 10, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Delayed brewing
The problem is in the sensor that tells the coffee maker when the brew cycle is complete. This is a heat sensor that's clipped to the heating element. The sensor gets overly sensitive and shuts things off too soon. Since schematics and parts aren't available for this unit, it's pretty much junk after it starts to fail. You can remove the sensor, but this creates a major fire hazard. My advice is to pick up a good percolator and forget the drip units. The Grind-N-Brew makes excellent coffee, but they barely last out the warranty and the cost of replacing them mounts up. I've gone through two (same problem with both) and it's no longer worth it to me.
Oct 04, 2007 | Cuisinart DGB-500 Coffee Maker
Cuisinart DCC-1200 Coffee Maker Logo
293 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
