The programme board is lighting up and we woul like to reset the programme with error code E40
SOURCE: RE: ERROR E40 ON ELECTROLUX ZANUSSI JETSYSTEM 1200
hi there e40 fault could either be your door interlock or main pcb
SOURCE: Zanussi Turbodry jetsystem 1200
hiya
e90 means there is a communication error between the circuit boards inside. remove the plug then take the lid off the machine, remove the block which has the 5 (iirc) blue wires in it and give it a quick squeeze then replace, this should hopefully solve your problem.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
SOURCE: zanussi zwf1631w error code e40
hiya
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
SOURCE: zanussi zwf1430s error codes - E40 / E41 & ELE
hi
ele means the pcb is in factory settings . all you need to do is turn back off the on again then will be back to normal use. but e41 usally means the door lock has failed. does it click alot when you start it up and not do anything? if so this will be the lock
regards
SOURCE: Zanussi Washing Machine Troubleshooting, Problems BY EORR E40
E40 is code for the door being open. Try closing/slamming the door hard a few times
