Question about LG Dishwashers
Dish washer displays pf code
I need to know what code pf means
    Problem Solver:
  • 8 Answers
PF is probably PE like mine, sometimes the bottome row of the liquid display doesn't work properly
PE is a Pressure Error - condition - The water level in Tub goes down during operation
Possible Causes
¥ The Circuit of Pressure Switch
shorted or disconnected.
¥ Pressure Switch is troubled or
disconnected
¥ The Controller is troubled.
¥ The Air Tube is kinked or damaged.
Possible solutions
¥ Repair or replace the Circuit of
Pressure Switch.
¥ Replace the Pressure Switch.
¥ Repair or replace the Controller.
¥ Remove the cause of kink or replace
the Air Tube.
Posted on Jul 20, 2009
When washer starting to spin it faults out with code pf. Then washer just powers down. What does this mean?
Hello!
Code PF means that a power failure occurred on the control board during the program run.
In most cases, the reason for the code PF on the display is not in the washing machine, but in the problems of electricity supply of your house or apartment.Turning off the electricity or a power surge most often results in this error.
May 18, 2017 | Washing Machines
How do I make it shut up?
You probably have an error conditon. Is anything displayed on the control panel? If it's displaying "PF", that means "Power Failure". Press the STOP or CANCEL button, then set the time. That should stop the beeping (if it's displaying PF). if any other error code is displaying, I would need to know your range model number, and the code that was being displayed.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 13, 2015 | Kenmore Electric Smooth Top Stove
PF code
Depending on manufacturer and model, PF can mean a number of things. On my stove, PF simply indicates "Power Fail" Yours may, too. You can clear this generally by updating the clock display. To verify that PF does indeed mean power fail for your stove, simply shut off the power for the cicuit than supplies the stove. This can be either circuit breaker or fuses. Turn the power back on after 5 or more seconds and if it displays PF again, you know it means power fail.
Otherwise, please provide the manufacturer and model of you stove for an answer.
Jul 02, 2012 | Ovens
We are getting an error code of "PF" and can't
Here is a tips that I wrote that will help to explain why you get the PF Error Code
PF Error Code for Appliances
heatman101
0-=0
Oct 31, 2010 | LG WM3431 Front Load Washer / Dryer
What does PF mean? on the electronic display
The code PF indicates that a power failure occurred while the dryer was running. Press pause/cancel to clear the display. Hope this helped and best wishes.
Jul 26, 2009 | Kenmore HE2 Plus Front Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error code PF
PF means Power Failure!
Unplug both units for 10 minutes, then plug them back in and try operating them. You may need an electrician to investigate why you are losing power to both units
Jun 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Won't run
found a pf not an a fp
PF Power Failure PF flashes if the washer loses power during a running cycle. The washer does not flash PF when it is first plugged in.
Press START to continue the cycle from the moment that power was lost -OR-
Apr 04, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
WHIRLPOOL SLIDE-IN RANGE
PF means power failure.  Usually you can hit cancel or clear and this will go away.  Let me know if this helps.
Oct 12, 2007 | Whirlpool RF378 Electric Kitchen Range
Dishwashers Logo
370 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
