Question about Philips 42PF9631D 42 in. Plasma Television
3 year old Philips 42PF5321D/37 TV no longer turns on.
The green LED turns on but no A/V. The A/V would only turn back on if I unplugged/ plugged the set. But It would take +1 minute before the picture would be visible and the picture would turn on then off then on then off before it stabilized. Philips asked me to do a firmware upgrade, but I was already at the latest version. I tried to re-install the firmware but nothing seemed to happen maybe since I have the same version as on the USB. The TV continued to work for several weeks as long as I unplugged and plugged the power. Today I am unable to get any A/V at all.
  • 2 more comments
  • deshome Jul 21, 2009
    I unplugged the unit for 24 hrs- no change. I was able to turn it on one more time, but it took many times plugging / unplugging. It has been getting progressively worse in that respect. There are no flashing LED's. The LED is steady green. I was able to get into the CSM mode and found that it has an error code of 04.
    I have started to take the back off to look inside. 'Hoping to find something obvious -
  • deshome Jul 22, 2009
    Interesting enough, most of the IC boards are labeled w/ Samsung, not Philips! I'm looking at the power supply board and see two 3300 uF caps that are bulging at the top. But I see no leakage or loose solder anywhere.
  • deshome Jul 23, 2009
    Well, nicolocarlo had already pointed me in the direction of the bad capacitors on the power supply. So I am working toward replacing them. I wasn't able to get replacements locally so I have ordered some and they should be delivered in the next couple of days and I will know then if this works. It sounds like this maybe is a common problem?
  • deshome Jul 28, 2009
    Thanks! nicolocarlo helped me to discover bad capacitors on the power supply. rulds2008 confirmed it. I replaced the capacitors and now my TV works like new!! I'm very happy I discovered FixYa!
  • Philips Master
  • 3,866 Answers
Listen if you see bulging capcitor replace them you be glad you did and you will have a working TV!! Trust me i did this on a Emac even though there not the same type of unit it really doesn ot matter the problem is this a bulging cap means its not holding its correct charge and thus not able to power the rest of the TV!
Change the caps you be a happy camper you did and you will S$VE big cash!!! If you did Trust me
Thanks for using fixya I hope this helps you! If it does hit accept you be glad you did!
Rulds2008
Posted on Jul 22, 2009
  • Grand Canyon Tech
    Grand Canyon Tech Jul 23, 2009
    Well capcitors over time and heat do that and when the do yes it can be a common problem with all eletronics, remeber a good clean unit is a good running unit key it clean and free from dust, dust kills it has static eletricity that builds up a charge and if that hits a sensitive device then it would be a lot more difficult to replace.
    Thanks please hit the accept button
    Rulds2008
    President:
  • 2,923 Answers
Firmware upgrade is not the solution. There's a hardware problem inside the TV. You need to replace the INVERTER BOARD. Check the link below so that you could have an idea how the inverter board looks like:
http://www.shopjimmy.com/catalogsearch/result/index/?q=inverter+board&stock=all
Hope this helps and have a great day!
Posted on Jul 21, 2009
  • Melvin Ramos
    Melvin Ramos Jul 21, 2009
    http://www.shopjimmy.com/catalogsearch/r...
    President:
  • 2,187 Answers
You can do a reset if you leave the device unplugged longer. I had mine unplugged overnight and it solved all issues within the 3 years of use. If it does not solve it you may check for loose connections internally. If there are internal components that may fail the TV should give out errors by flashing of lights. See if there are any.
Posted on Jul 18, 2009
  • Nicolo Carlo Parazo Jul 21, 2009
    In that case you need to look for leaks in the capacitor or soldering that had gone loose. If you know how to use a tester you can test if there are no power to some of the IC which could mean it is faulty. The solder and the IC may go bad due to heat which is one of the common cause of breakdown along with surges in the power.
    Just to add... Inspect the power supply first. The first component that is connected to the power. See of there are leaks coming out of the capacitor. Check if there is voltage coming out of it using a tester.
I have a Philips 42pf5321d/37 that won't turn on.
send me a email sonny@tvcircuitboards.com and I can assist you with troubleshooting it to determine whats happening with the set.
Aug 07, 2012 | Televison & Video
Plasma tv in protect mode
One of the PCB's inside has an incorrect voltage/short or dry joint, all TV now days have a diagnostic startup mode which checks all the boards, one of yours threw up a problem so the TV put itself into Protect Mode so that it doesn't do anymore damage.
Get it checked out by an engineer.
Thanks
Oct 01, 2009 | Televison & Video
Philips 42PF5321D/37 Plasma No Picture Six Red LED Flashes
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Mar 12, 2017 | Philips Televison & Video
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
42 Philips Plasma 42pf5321d/37 green light on no AV no Menu nothi
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsung, Known to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio connections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H. 2nd more of a long turn approach to your system. You might look at a Power conditioner to ensure constant clean Voltage & current to your Set, Price I know running about $150 to $200, but this will protect your set from a Spike and under voltage swings from the 110V plug. Surge protectors only help the Spikes on the 110v Line not the Drops. Hope this helps
May 29, 2009 | Philips 42PF9630A 42 in. Plasma Television
I had the Same issue. on a 50PF9431D/37 set. Many Plasma Set's use a LJ44-00118A PS-505-PH Power supply from Samsun. Know to have this common problem. If you can, or have a friend that can Solder components?. Unplug your set remove the back panel & locate your power supply. It will be the PCB in the center of the set just above the Video/Audio conections. http://www.shopjimmy.com/power-supply-unit-lj44-00118a-from-philips-50mf231d-40.htm. Link to a photo of the PCB. Make a note of the location of all cable connections then unplug them all. Un-install PCB, Check a Fuse first. I believe their is 5 or 6 of them on the PCB. Then replace the two 3300uf 10v 105C Radial capacitors at C8060 & C8059. The location of the caps are in the Lower bottom edge of the PCB. A local shop may Carrie them if not, digi-key has them. Part # http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=493-1754-ND. Total cost was $7 with S/H.
May 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Flasing red light where the on light is
I have a philips pf50 9630a/37 tv may come on or it may not unplug it and take a chance then comes the 6 steady red flashes followed by 3 rapid red flashes the screen had been completely replaced by philips a year and a half ago
Mar 22, 2009 | Philips 50PF7321D 50 in. Plasma HDTV
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Shutdown; red LED blinks 4x
The most likely reason for the no picture might be the back light is gone and needs to be replaced, now as for the LED light blinking on different intervals is because its diagnosing it self unfortunately the user manual does not have any information on this part only by contacting the Phillips customer support you might get a better idea, but check your back light first it may just be that. Also try to check your Manufacturer warranty repair.
Sep 07, 2007 | Philips 50PFP5332D 50 in. Plasma...
Philips 42PF9631D 42 in. Plasma Television Logo
120 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
