Question about Homelite Consumer Products Tiller Attachment
Homelite edger will not start. cleaned carbs, drained and replaced gas, cleaned screen.
  • 714 Answers
You have to have fuel.fire,compression to run ,make sure you've got that and the thing should run,try a little starting fluid
Posted on Jul 18, 2009
Homelite 26tv wont start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 21, 2009 | Homelite Mighty Lite Lawn Trimmer
My homelite mighty lite edger starts, but will only run on either half choke or run for 10 or 15 seconds and then dies. The choke filter looks clean.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
You may have to replace them.
Jim
I have a Homelite gas trimmer model UT20760. It will start, but won't accelerate.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
Jim
Jun 18, 2009 | Homelite Garden
My trimmer starts easily, runs well for about 1/2 tank of fuel, then bogs down, 1/2 running, may speed up if turned onto its left side, or may run on 1/2 choke. What could be the problem?
The problem is the carburetor is dirty or the carb. parts are old and need to be replaced. First try to clean. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen in the carb. is free of debris. Use a Den tek brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassmble and start.
(NOTE: If the carb. parts are more than 3 to 4 years old, then you should gop ahead and buy a carb. kit and replace all appropriate parts.
Jim
Jun 11, 2009 | Homelite Mighty Lite Lawn Trimmer
My homelite weed wacker will only run in the choke position
Check the fuel lines for breaks/cracks. If they are o.k. then you will need to clean the carburetor. Disassemble the carb. and spray with carb. cleaner. Make sure the small screen in carb. is free of debris. Use a Den Tek Brush,(http://www.amazon.com/dp/B000V5MQ7Y/ref=asc_df_B000V5MQ7Y820727?smid=AKZ54EXMVZHXW&tag=dealt5228-20&linkCode=asn), to clean the small portals in carb. Reassemble and start.
NOTE: If your carburetor internal parts are more than 4 yrs. old, you may want to replace them. So buy a carb. kit.
Jim
Jun 10, 2009 | Homelite Mighty Lite Lawn Trimmer
Trimmer fires up but then stops , I pump the bulb and it starts again but then stops
Ok... 1. Make sure your Air Cleaner is clean 2. Empty out any old gas in the system from last season. from the tank, carb, and fuel lines. 3. Make sure that the gas filter in the tank is clean and free from blockage. 4. Clean out the carb jets with spray carb cleaner. 5.Pull spark plug and clean wih carb spray as well. 6.. Reassemble n fill with fresh gas/ or gas/oil mix if 2 cycle. let me know how it goes... k
Jun 10, 2009 | Homelite Garden
Mightylite 26cc Edger
You need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.dentek.com/shop.php?target=products&product_id=7), to clean the small portals in the carb. Make sure to clean the small screen in the carb. as well. Reassemble and start.
Jim
Jun 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Starts but when throttled continues to die
You have carburetor problems. You will need to take the carb. off and disassemble. Clean the carb. with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb. to make sure it isn't clogged. The smallest of particals can cause the carb. problems. Check the gaskets as well. Depending on how old your trimmer is, you may have to buy a carb. kit and replace the Needle valve, appropriate gaskets, diaphragm, and small screen.
Jim
May 30, 2009 | Homelite Garden
You have a dirty carburetor or a carburetor in need of new parts. Disassemble carburetor. Clean with carb. cleaner and use a Den Tek Brush, (used for cleaning teeth), for the small portals. Check the small screen in carb., making sure that it's free of debris. Reassemble and see if it works properly. If it doesn't, then you will need to buy a carb. kit and replace the small screen, needle valve, appropriate gaskets, and diaphragm. This should do it.
Jim
Engine dies when excelerating - more gas
check the fuek lines for hole and leaks, check the fuel filter and clean if necessary. remove the carbuerator and inspect the gasket; it should be soft and flexible, if it seems hard or brittle replace it. clean the carb with carb cleaner sray (available at any local auto parts store) and compressed air. make sure you get inside the small fuel rail holes. if that doesn't work have the carb repaired at a service center or replaced.
Nov 17, 2008 | Homelite Mighty Lite Lawn Trimmer
Homelite Consumer Products Tiller Attachment Logo
406 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
