Question about Ricoh Aficio AP3800C Laser Printer
Fusing unit is not set properly
I replaced the fusing unit and when I turn the printer back on, I get this message : "Fusing unit is not set properly". Any idea ?
The old one and the new look the same... I don't see what is wrong.
There was a message in the box : "Donot turn the blue dial at the side...". I didn't turn it.
  • marcv Nov 19, 2007
    I don't know the purpose of this blue dial. Why Turning it is "bad" ? Id didn't know there was a fuse, where can i find it ?
    I don't see any "0". I see only "B3" written on this side. I tried putting it in the same position as the old fusing unit but no change.
    I tried several times to put the old one than to put the new one, and always the old one is working and the new one is not.
    Sergeant:
    Champion:
  • 306 Answers
Possibly the dial was turned..try replacing the fuse, if problem still exist contact the manufacturer or take it back for a replacement.
Posted on Nov 19, 2007
    Filmmaker:
    Uploaded 5 video answers.
  • 150 Answers
Turn the printer off and reinstall the unit after it has cooled off (30 minutes). Then open cover B and D. Remove the fuser unit, then reinstall it properly. Close covers D and B. The error clears automatically if the fuser unit is properly installed.
If the error is not cleared, the fuser unit is out of order. Replace it with a new fuser unit.
  • shivam raj
    shivam raj Nov 19, 2007
    it is recommended you
    set the blue dial to the “0” position
Error cs548 in ricoh mp c4500
SC548
Fusing unit rotation error
The fusing belt sensor does not detect change in the actuator for 0.5
seconds after the fusing/paper exit motor has turned on.
* Defective fusing/paper exit motor
* Deformed actuator for the fusing belt sensor
* Defective fusing belt sensor
* Broken connection between IH inverter and IOB
* Incorrectly set fusing unit
1. Check if the fusing unit is correctly set.
2. Check or replace the actuator for fusing belt sensor.
3. Replace the fusing belt sensor.
4. Replace the IH inverter.
5. Check the connection between IH inverter and IOB.
Jul 14, 2014 | Gestetner DSm645 Digital Imaging System
How do I replace a Fuser ?
Sir/Madam
The Problem Is Very Simple ,You Need To Follow Few simple Step To Fix This Issue
  • Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  • Open the back cover (1) and the scanner unit (2) of the machine.
  • To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  • Hold the handles on both sides as you take the fusing unit out of the machine.
  • Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  • Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  • Move the fusing unit pressure release levers to the Set position.
  • Close the scanner unit and the back cover.
  • Turn the machine's power switch back on
  • Press the Menu/Set key.
  • Press the up or down navigation key to select Machine Info. and press Menu/Set.
  • Press the up or down navigation key to select Reset Menu and press Menu/Set.
  • Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
In case You Need More Help Then Go To Official Brother Printer Help Page Below:
http://welcome.solutions.brother.com/BSC/public/eu/eu_ot/en/faq/faq/000000/000000/000021/faq000021_002.html?reg=eu&c=eu_ot&lang=en&prod=mfc9420cn_all
Or If You Still Facing Problem Then Follow Us On:
Brother Printer Support
Jan 08, 2014 | Brother HL 2270DW Laser Printer
How do I replace the brother fuser?
    The fusing unit and the parts around it are hot! Be sure to wait until the fusing unit has cooled down sufficiently before replacing the fusing unit. If you touch the hot parts, you might get injured.
  1. Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  2. Open the back cover (1) and the scanner unit (2) of the machine.
  4. To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  6. Hold the handles on both sides as you take the fusing unit out of the machine.
  8. Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  10. Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  12. Move the fusing unit pressure release levers to the Set position.
  14. Close the scanner unit and the back cover.
  15. Turn the machine's power switch back on.
  16. Press the Menu/Set key.
  17. Press the up or down navigation key to select Machine Info. and press Menu/Set.
  18. Press the up or down navigation key to select Reset Menu and press Menu/Set.
  19. Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
  20. Press 1 to reset the life counter.
  21. Caution
      Please be careful when replacing the fusing unit. Do not put pressure on the fusing unit; it should go in easily. If it does not, make sure the fusing unit connector is free to move.
      Do not apply force! It could damage both the fusing unit and the machine.
Feb 02, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
H5-01 error on sharp AR-M450N
Sharp AR-450 H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error C1 00 MC unit malfunction C2 00 TC unit malfunction E7 00 Image Processing Unit error 01 Memory back-up battery dead 02 Laser unit problem 03 HDD defective 10 black level calibration error 11 white level calibration error 13 CCD calibration error 90 Image Processing Unit error F1 00 Lost communication with the Sorter 01 Sorter registration problem 02 Paper transport motor overloaded in sorter 04 Bin position error in sorter 05 Bin position error in sorter 06 Shift sort motor overloaded 08 Stapler position error 08 Stapler overloaded 11 Sorter problems 14 Second shift tray jammed 15 Sorter drive problems 50 Sorter not installed properly 80 No powerin sorter F2 00 ID pattern reading error 02 Toner add mechanism malfunction 31 ID pattern reading error 32 ID pattern reading error 39 Drum thermistor error F3 12 Paper does not lift in the tray 22 Paper does not lift in the tray F9 00 Printer board problems 01 Printer board problems 02 Printer board problems 03 Network card error 04 Firmware error 05 Not enough memory 10 Printer board problems 90 Printer board problems H2 00 Fusing unit temperature error 01 Fusing unit temperature error H3 00 Overheated fusing unit 01 Overheated fusing unit H4 00 The fusing unit doesn't heat up 01 The fusing unit doesn't heat up H5 01 Papersensordefective in the fusing unit 02 Fusing unit temperature error L1 00 Scanner position error L3 00 Scanner position error L4 01 Main motor drive overloaded L6 10 Polygon mirror motor not up to speed L8 01 Zero cross signal error 02 Zero cross signal error U2 00 EPROM error 11 EPROM error U4 02 Duplex not working properly 03 Duplex problems U5 00 Communication with the ADF is lost 01 Registration sensor problem in ADF 02 Exit sensor error in ADF 03 Timing sensor problems in ADF 11 Paper feed drive overloaded in ADF U6 01 Paper lift problem in 1'st optional tray 02 Paper lift problem in 2'nd optional tray 08 Paper feed unit without power 10 PFU paper transport motor overloaded 22 Paper feed unit without power 50 Paper feed unit not installed properly 51 LCT not installed properly U7 00 Main board malfunction U9 00 Op panel problem 90 Op panel problem EE EU Low toner density in the developer EE EL High toner density in the developer FA 01 Memory back-up battery dead PC Key counter not installed
Apr 01, 2010 | Sharp AR-M450N Copier
I have a Functional Problem. The little wrench shows on the User Tools / Counter button location and on the screen. The Functional Problem code looks like SC542-00. It tells me to shut off copier and turn...
SC542: Fusing temperature warming-up error The fusing temperature does not reach the fusing standby temperature within 135 sec (35CPM machines) or 145 seconds (45CPM machines) after the main power switch is turned on. - Possible causes - • Fusing thermistor defective or out of position • Fusing lamp open • Fusing thermofuse open • BICU defective • Power supply board defective • Poor fusing unit connection
Sometimes by going into service mode and then turn off copier and back on will clear this message or while in service mode do an error clear. But most of the time it is the thermistors in the fixing unit needs to be cleaned or replaced. I would probably call in the techs.
Mar 21, 2010 | Ricoh Aficio 450 Copier
Replace fusing unit error
Can you put the old fuser back, just to see if the message clears.
Mar 04, 2010 | Ricoh Aficio AP3800C Laser Printer
Problem replacing fusing unit for a Ricoh Aficio SP C411DN
Look in your owners manual for the set of reset keys you ppuch to reset the error in the machine. Can't tell you much other than it is a sequence like holding POWER button and 1 or 2 other keys for so many seconds. Have you tried to ask the question at their website?
http://www.ricohpr.com/
Here is the location for the manual
http://www.ricohpr.com/about/awards/pdf/2006/Ricoh%20Aficio%20SP%20C411DN%20LTR%20%5B34246%5D%20Reprint.pdf
Jul 15, 2009 | Office Equipment & Supplies
Purchased new fusing unit for ricoh cl3500n; installed; tried to reset computer by holding escape for 5 seconds; does not clear out error message 'replace fusing unit' ; nothing will print; can not get to...
You need to enter service mode, (this really should be done by a ricoh tech) Turn off printer press and hold down online and escape and turn printer on, the panel should sho a 1 2 3, push 2 for engine and enter press 7 and enter 804 is the counters for supplies. #4 is the fuser press enter after the printer says execute. Back out with escape and 3 to exit, cycle power. -Carl
Jul 07, 2009 | Ricoh Aficio CL3500N Laser Printer
Ricoh AP3800 COLOUR Laser Printer
SC 556 Pressure roller fusing lamp temperature fluctuation
The pressure roller
temperature changes by
±20°C or more in one second.
This occurs three times in one
minute or two consecutive
times.
• Loose connection of
the pressure roller
thermistor 1. Check if the fusing unit is properly set
and connected to the main frame.
• Loose connection 2. Check if the pressure roller thermistor
connector is firmly connected.
between the fusing
unit and main frame
3. Replace the fusing unit.
Nov 17, 2008 | Ricoh Aficio AP3800C Laser Printer
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Ricoh Aficio AP3800C Laser Printer Logo
524 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
