Water wont drain, l cant figure out how to get inside...son said he smelled burning...must be a belt, right?
    Brigadier General:
  • 4,088 Answers
The first thing to figure out is how to open the top. Older GE top loaders had to have a thin putty knife inserted straight back at each front corner to release the top. Others require removal of screws at top back--push back on top and hinge up in front. That allows access to the interior and screws at both sides that release the front panel. Lift up to take the panel out. These are general instructions because you didn't identify the washer make and model.
Posted on Jul 18, 2009
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
It doesn't drain out the water. Doesn't go through the cycle
hello,
  • Check the draining system for clogs and kinks. First, check the draining hose in back of the washing machine. In Whirlpool models, this hose easily becomes kinked and can block the flow of water. Check the lint filter for clogs. Finally, check the side-check valve, which is located at the tub outlet.
  • 2 Run the washer through a cycle with nothing in the tub. One of the common symptoms of a jammed Whirlpool motor is a nonrotating tub and a burned smell. The belt that powers the pump produces the smell. When the pump gets jammed, the belt begins to split off, causing friction and the burned smell. If you have these symptoms and find a damaged or broken belt, always replace the pump along with the belt. Otherwise, you will damage a new belt instead of fixing the problem.
  • 3 Check for objects in the drain tubes and pump. To get to the pump and hoses, manually drain the tub and unscrew the back panel. Detach the hoses with a wrench and feel inside them for debris. If you cannot find anything in the hoses, feel inside the pump inlets and outlets with piers and remove any debris
  • thanks
    Oct 23, 2010 | Dishwashers
    Burning rubber smell from my maytag stacker washer and the water wont drain
    Most likely the water pump belt is slipping or the water pump could be locked up.
    Sep 03, 2010 | Maytag LSE7806A Top Load Stacked...
    Replaced belt, new belt is burning when pump engages
    hi i have the same washer and i can't figure out how to change the belt. please help. anthonylombardojr@hotmail.com
    May 10, 2010 | Amana Washing Machines
    Tub not spinning smell rubber
    If your washer does not drain you need to check this parts.
    1. Inspect the drain hose for kinks
    2. Test the timer control
    3. Test the lid switch(some models)
    4. Inspect the water pump
    5. Inspect the drive belt(belt drive only)
    6. Inspect the motor coupler
    Some part of the motor burned out that's why you can smell burning rubber. Check some faulty parts.
    Mar 28, 2010 | Maytag Washing Machines
    Agitator spins slowly and wont drain water-slight burning smell when operating
    Hi, Th smell is most likely the belt. If the washer is not draining, the pump could be locked up and this will cause the belt to smell.
    The pump is located underneath rear right corner. If you set the drain hose itno abucket and get the water out. you can tip the washer back and see if the pump is froze. I see you posted this premium but I didn't get to it in time cause I was asnwering this.
    Hope it helps
    Vic
    Jun 21, 2009 | Maytag Atlantis MAV6451 Top Load Washer
    Burned belt?
    Yes, smell like your belt.. if there is water in tub, try to get it out... (wet vac)... slide your washer out and tilt it back so you can see under... there should be 2 belts.. 1 for gear and 1 for water drain pump... and you can check Sears.com for parts.. good luck...
    Jan 23, 2009 | Maytag SAV5710 Top Load Washer
    I have a maytag washing machine model #SAV3710AWW. The water will not drain and it smells like a belt is burning
    you may have a sock stuck in the drain keeping it from draining. the burning belt would be from running it and trying to get it to drain when it cant
    Dec 28, 2008 | Maytag SAV3710AWW Washer
    Hotpoint Aquarius WT540
    Sounds like the water pump is plugged with something. The pump could also just be locked up. The smell is probably the belt slipping on the pulley. To drain the unit you will need to lower the drain hose into a bucket and let it drain that way. Most pumps can be opened and cleaned. It will be inside and attached to the drain hose. It has a pulley on it where the belt rides. If it has a clamp holding the bottom on remove it and the clog. You may be able to do this without removing it from the unit. Let me know if you need further help.
    Feb 09, 2008 | Hotpoint Aquarius WD63 Front Load...
    Washing Machines Logo
    61 people viewed this question
    Top Washing Machines Experts
