Question about D-Link DI 514 Wireless Router (DI-514)
Same problem I need help with the ip address...and I am sort of computer illiterate when it comes to technical things
    Scholar:
  • 87 Answers
Your router should be factory reset. There is a reset button on the unit that will require a paper-clip to reset. With the unit 'on' press and hold the factory reset button.
Your PC should be set to automatically acquire a suitable IP Address form the router. The router is also set to automaticlaly acquire the right IP address from your ISP. However somtetimes you may need to put in a 'username' and 'password'.
Posted on Jul 26, 2009
  • 4 Answers
HI
click on start ::run::write "CMD"::a black screen will come up plz write::ipconfig and u will get the ip address
Posted on Jul 23, 2009
Connect fuji xerox printer - mac pro computer as it was
Hi Lindsay. Was the fuji xerox printer plugged into the old modem by a blue ethernet cable ?
When you changed your modem it would have had a device inside it called a dhcp server that allocated the IP addresses to your computers automatically.
Now I suspect that the new modem has a device inside it called a DHCP server that is allocating a different range of IP addresses to your computers from waht it used to be.
Here comes the technical part
On the printer menu screen there should be a network setting option . Take a note of the IP address of the printer it will be 192.168.0.x or 10.0.0.x x being the unknown number. also take a note of the subnet mask . it will most likely be 255.255.255.0
next but I have no idea how to look that up on a MAC IOS system.
you may see the ip address in the printer settings properties in the MAC
you may be able to get your ISP to remotely set up your DHCP server in your router to work in the appropriate ip range to match your printer IP address and to avoid allocating the printers ip address to your computers. Then restart the computers to get new ip addresses.
If you tell them the printers IP address and Subnet mask they should be able to alter the modem's settings DHCP settings for you.
The other option is to get the DCHP IP address range of the modem and subnet mask and change the printers IP address setting and subnet mask to match the DHCP leases range by giving it a much higher number than the computers are most likely to be running on.
so if the range was 10.0.0.1 to 10.0.0.254 with subnet mask of 255.255.255.0 then the printer would be set to 10.0.0.254 and subnet mask 255.255.255.0 The first three left numbers must match they are known as the network component of the ip address 10.0.0.0 or it may be 192.168.0.0 the zero end number is the network address so you can't allocate it to a device. 192.168.0.1 or 10.0.0.1 is usually the modem address.
ISP may be able to guide you how to change the setting on the printer .
I had a client that had a lot of trouble getting a tech to come out and set up their printer to an APPLE system. I was the final Tech that eventually came out and set up the printer .
Feb 17, 2016 | Computers & Internet
I'm told I need to close get rid of about 7 IP addresses that are imposed on my computer. Can I do it myself?
www.malwarebytes.org One of the better virus/malware removal tools. Download the premium trial. They give you two weeks free, its really simply to use.
Jan 19, 2015 | Gateway Computers & Internet
Uf 9000 ip address
Just wondering if you've found a solution. I'm trying to do the same thing on our uf-9000. Any help would be appreciated.
Panasonic technical support is not good.
Oct 21, 2013 | Panasonic Panafax UF-9000 All-In-One Laser...
We are trying to download the drivers for a network but it is asking for the IP address IPv4 and we don't have it. Could you provide it.
well check your printer machine IP address...just like a computer printer machine have their own IP.then use the IP of you printer...
Jul 21, 2011 | Panasonic Workio DP-190 Multifunction...
Connecting 2 computers to a SohoWare ND4025. I would like to connect two computers to this router in order for them both to use internet. The network, is set up right now, the computer im typing on...
With firewall disabled, try setting the ipv4 properties of your connection as follows: ip address:
obtain an ip address automatically.
DNS
Obtain DNS server address automatically
since this is a peer to peer network you have to understand that the two machines are independent of each other so if this is not the settings on your first machine, please duplicate the exact settings of the first machine on the second machine. The hub might be distributing specific requirements from the modem. Hope this helps
Jun 07, 2011 | SMC SoHoware ND4205 Networking Hub
C309 shows off line on some computers and we have to turn them off to print then on
What may be going on is every computer has this identification called a IP ADDRESS this is what you internet identifies your computer with, your printer also has one of these. What i have seen happen is when you install your printer onto a computer the computer gets the printers IP ADDRESS so it knows where to print to. If you have a Hub/Router that is fairly old sometimes they drop IP ADDRESS and then have to make a new one for the device, So if your printer is connect and then drops connection from your interent the IP ADDRESS gets reset on the printer, So when your restarting your computer then your Computer is saying oh look the printer has a new IP address I better connect to it. That's why once you restart you can then connect. The best way to fix this is to give your printer what is called a STATIC IP ADDRESS this means it will always have the same address to connect to! This can be a very technical thing to do yourself, I would recommends having a computer person set this up for you!
Jan 27, 2011 | HP Photosmart Premium C309A All-In-One...
I am having problems with my modem and wireless router. Someone told me I need to " redo my ip address to my computer but am unsure how to do this, can someone help me please
To renew your ip address go to start, in the search box type cmd. A black box will come up with a C: where the cursor is blinking type the following... ipconfig /release and it will go through its thing. When the C: comes up again, type in the following.. ipconfig /renew This will refresh your ip address and hopefully allow you to gain access to the net once again. Let me know if this helps.
Oct 09, 2010 | Linksys Wireless-G Broadband Router
I recently purchased the D-Link Ethernet Broadband router DI 504M. I've followed the instructions provided twice, but it will not allow me to connect to the internet. I can connect to the internet with my...
it seems to be just settings for the new device your lacking.
log on to the router as ADMINISTRATOR,
Windows 2000/XP -
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (e.g. 192.168.0.1 or 10.1.1.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Hope this helps ,
Please Rate Me ,Cheers Misterdj
Apr 10, 2010 | D-Link 4-Port Ethernet Broadband Router...
Grr
The camera has an IP address and if it is connected to your network via cable or wireless, you should be able to view it in your web browser just but entering the address of the camera.
Oct 12, 2008 | Linksys (NH1005) 5x10/100 Mbps Networking...
Utorrent downloads with WRT54GL?
Before we can forward ports for Utorrent, we need to figure out what ports Utorrent is using. Here is a brief walkthrough on how to do that. Go ahead and open up Utorrent.
Click Options in the menu at the top of your screen. In the list that drops down click Preferences.
Click Connections on the left hand side of the Utorrent program. You should now see the menu shown in the screenshot above. Make sure the Enable UPnP box is unchecked. The number in the Port Used for Incoming Connections box contains the port you need to forward. You can change the port number, if you want to. Please enter the port you chose into the box below.
Utorrent's Port for incoming connections To setup port forwarding on this router your computer needs to have a static ip address. Take a look at our Static IP Address guide to setup a static ip address. When you are finished setting up a static ip address, please come back to this page and enter the ip address you setup in the Static IP Address box below.
Do not skip this step! Please enter the static ip you want to forward to: 192.168.1.
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is blank, and the password is admin. Click the Ok button to log in to your router.
Click the Security link near the top of the page.
Remove the checkmark from the Block Anonymous Internet Requests checkbox.
Click the Save Settings button near the bottom of the page.
Click the Applications & Gaming link near the top of the page.
You should now see a new menu. In this new menu, click Port Range Forward.
Port Range Application Start End Protocol IP Address Enable To Both 192.168.1. We will list a series of lines here that will show you exactly how to forward the ports you need to forward. Utorrent requires you to forward the ports you entered above. Go ahead and enter the settings shown above into the Port Range Forward menu.
When you're finished, click Save Settings near the bottom of the screen to save your changes.
And that's it! You're done!
Feb 21, 2008 | Linksys Wireless-G WRT54GL Router
D-Link DI 514 Wireless Router (DI-514) Logo
103 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
