Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Check Signal Cable
I just purchased a Dell Precision 390 -- the video card is 128MC PClex16 Nvidia, Quadro NVS 285, dual DVI or VGA. In order to get a crisper image I purchased an adapter/cable to hook up DVI, the monitor keeps stating "Check Signal Cable, Analog." Is there something that I need to do to switch to digital? I have check all my connections and everything seems to be connected.
Thank you,
    Problem Solver:
  • 17 Answers
Re: Check Signal Cable
There maybe something called source on th screen somewere push that button
Posted on Nov 19, 2007
0 characters
3 Points
DVI problem with latest drivers
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
May 09, 2008 | Dell UltraSharp 1900FP 19" Flat Panel LCD...
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Apr 22, 2014 | Acer ET.CV3WP.E05 LCD Monitor - V193WEJb...
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector,...
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
Feb 21, 2011 | Acer X193W LCD Monitor
Monitor displays message "Out of Range" when trying to set the resolution to 1600x1200 I have NVIDIA Quadro NVS 160M video card with native NVIDIA driver installed
The max resolution to your monitor is 1680x1050. The video card can't help you with the resolution if the monitor doesn't support it.
Sep 24, 2009 | BenQ G2000WD 20 inch Monitor
"No signal detected" when LCD connected with DVI-D Cable
Thank you for providing your configuration details.
You have failed to specify wheather or not your LCD Display is under Warrenty.
Perhaps these simple trouble shooting procedures will get the job done.
1. use the DVI to VGA adaptor that came with your card
Plug in a regular CRT monitor to the Primary Display Output Port using the DVI to VGA adaptor
( either port can be designated as the primary by you )
I like to use the Port nearest to the motherboard as the Primary
2. plug in the your LCD monitor on Secondary Display port using your DVI cable
At this point you should be able to see your desktop on the Primary CRT Display
3. Go to the display properties and use the Nvidia Dual Display Setup Wizard
set both desktops to CLONED at a resolution of 1024x768 and set the refresh to 60Hz
which is default for most LCD displays , some have higher refresh rates , consult your user manuel
If the display resolution and refresh are set incorrectly for your CRT or LCD you will see
Signal Out of Range ( if the display has the ability to display that error message )
At this stage both displays should be showing a Windows Desktop
If you now see your desktop on both displays , you can now put the LCD on the Primary Port
No Signal Detected ( this means the display device is not receiving a signal )
If your LCD display is still displaying the error message
"No Signal Detected" after performing the trouble shooting proceedures
You may need to read the user manuel about how to enable DVI signal input.
If you are certan you have done everything correctly but still see only "No Signal Detected"
Your LCD Display may need replacement
Loch Hime :-)
Sep 14, 2008 | BenQ FP71E 17" LCD Monitor
Screen goes blank when I move the mouse
Did it work properly using a VGA (analog) cable? If so, check your DVI (digital) cable against the pictures at the bottom of
You probably have one of the two at the left. Each has a different bandwidth, translating to a maximum resolution. The native resolution for your monitor might be marginal if you have a single-link DVI-D cable.
My 204B seems very picky about signal-level. It blinks when connected by DVI, even though it should be fine with a single-link cable, and complains about the settings even though the settings are optimal. Maybe yours is similar. I have ordered a dual-link cable and will try that myself.
Feb 13, 2008 | Samsung SyncMaster 204B 20.1" LCD Monitor
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
171 people viewed this question
Top HP Computer Monitors Experts
Ivan Bernal
Level 1 Expert
Tony Isted
Level 1 Expert
Elizabeth Mescall
Level 1 Expert
Are you a HP Computer Monitor Expert? Answer questions, earn points and help others
