Question about D-Link Xtreme N DIR-655 Wireless Router
Computer will not connect to internet through router
Internet connection is fine when PC is connected directly to HN 7000S Satellite modem using LAN cable but will not connect through D-Link DIR-655 router. Router does not find internet signal during setup procedure. Router network is functioning and allows other computers to connect to network but none have internet access via cable or wirelessly.
    Master:
    Sergeant:
  • 226 Answers
Check the connections between the router and the modem either cable or dsl or whichever
and change the setting in the router interface so you know what the ssid is being broadcasted and the network key
Posted on Jul 20, 2009
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
I have a DIR-600 router to connect my Cable modem and use wireless connection to connect to the internet. It was all working fine till my modem LAN port got damaged somehow.I have changed the modem and now...
Try following this order before you connect your computer to the router.
power off all your equipment (cable modem & router & your computer's wireless card)
first, power on the cable modem, give it some time to boot up and get an IP from the ISP, say 30 secs.
then, power on the router, again, give it some time to boot and obtain its internet IP from the cable modem
finally, enable wireless on you computer and connect to the router.
if this doesn't solve the problem try resetting the router to factory defaults by pressing the reset button at its back for about 10 seconds with the router powered on.
This your router's manual it may turn handy:
http://global.dlink.com.sg/site_support/DIR-600/Manual/DIR-600_B1_Manual_v2.pdf
good luck
Jun 12, 2011 | D-Link DIR-600 Router
Dell TrueMobile 2300 Router wont connect to My cable modem
You are most likely making a mistake in the setup instructions.
Jun 20, 2017 | Computers & Internet
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
Can connect to router, but router wont connect to internet
The router needs to be configured manually. Follow the steps below.
Step 1
Step 2
Step 3
Step 4
Step 5
Configuring router for Cable Internet
To configure your router for Cable you will need to set your router's WAN (INTERNET) port to 'Dynamic IP' (DHCP) option. The router is set to this option by default.
Step 1 Connect the cable modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Step 2 Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, default is `admin' and password is blank (nothing).
Step 3 After logging into the router select Setup. Set Internet Connection to 'Dynamic IP (DHCP)' option.
Step 4 Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration.
If you are having difficulties accessing the Internet, you need to:
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the cable modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your cable modem as well.
- Uninstall your antivirus/firewall software (sometimes disabling or closing the software is not enough) and reboot your PC. After establishing the Internet connection through the router, reinstall your antivirus/firewall software.
Oct 06, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
I have set everything up but its not working. The computer is showing a full bar, but the internet connection is saying its not connected.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Cable connections/router support
  • make sure that the modem has internet when connecting directly to the PC.
  • or else call your ISP
  • if internet is ok, check the cable from modem, is connected to the WAN/internet port/isolated port of the router,
  • then the PC is connected to any of the 4 ports of the LAN ports of the router,
  • then call your router brand manufacturer support to configure your router if the connection still to configure your router to get IP address from the modem
Aug 12, 2009 | Computers & Internet
Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Jan 05, 2009 | 3Com 7760 (3CRWE776075US) 802.11a/b/g...
DI 524 Connection Problem
Try the DSL modem directly connected to the PC.No D-Link Router (powered off and disconnected). Verify that the PC couldsurf/browse/connect to the Internet. Go to Start, Control Panel, Network Connections, right click Local Area Connection, Properties, scroll down to/highlight Internet Protocol (TCP/IP), Properties button. Get the IP Add, Subnet Mask,Default Gateway and DNS assigned to the PC (write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router. Go again to Start, Control Panel, Network Connections, right click Local AreaConnection, Properties, scroll down to/highlight Internet Protocol(TCP/IP), Properties button. Tick "Use the following IP address". Enter this IP Add 192.168.0.10, Subnet Mask 255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what you have written down earlier). This willbe your LAN IP settings. OK, close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Use the IP numbers previously assigned to PC that you have writtendown as the router's WAN/Internet/Modem IP settings. OK, close, save or whatever is applicable. Rebootrouter. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Belkin router
check you connections
DSL or CABLE Internet service connect to the routers WAN
Your PC connect to one of the 4 LAN, unless you are using wireless.
test Internet connection by directly connecting the modem to your PC, if that works the above should resolve the problem, unless the router is bad.
hope this helps
thanks for the rating
Jan 07, 2008 | Belkin (F5D7230-4) Router (587009)
D-Link Xtreme N  DIR-655 Wireless Router Logo
642 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
