Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Pool pump problem
My proline PE-II-H 1.5 hp just stoped working, it humms then turns off, this happened after i was vacuming the pool,HELP
    Sergeant:
  • 149 Answers
Possibly you picked up something that wrapped itself around the impeller of the pump. Pull out the pre-strainer basket located just before the pump and get a mirror and look inside the intake opening for the pump to see if there is any obstruction. The pump body may have to be taken apart to remove what's there. If nothing can be found, the next thing would be bad bearings. That would require a new pump, unless you think you have the savvy to replace them.
Posted on Jul 18, 2009
What does it mean if my above groung pool pump just humms when I turn it on?
Assuming you know how to operate the pump properly as far as bleeding air out and opening closing valves in correct order if applicable. I would suggest checking the impeller and filter housing for obstructions.
May 04, 2014 | Pool & Spa
Can't get impeller off proline pump
backwards thread screw then impeller turns off regular if you hold back of motor
Jun 16, 2012 | Hayward 1 12 Hp Super Swimming Pool Pump...
A. O. Smith 1 1/2 hp. motor Type SP. Humms then
You have a failing start/run capacitor. Take the motor to your pool supply place for repair.
Aug 03, 2010 | A.O. Smith Pool Pump Motor Square Flange...
Pump is making humming noise but not turning on. This happened after a breaker blu. I reset breaker and this is what happened.
This may just be the start celonide. Look's like a "D" battery or bigger in the back of the motor or on the top in a half round case. It is ment to boost the power to start the motor turning. If it bad the motor just humms till the breaker blows. Sounds like just what you have.
Jul 11, 2010 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
Dirty water coming back into pool
There is a spider gasket in the valve that could be broken or torn apart.
To check it seperat the valve at the handle and you will find the gasket
inspect .
The Pool Tech
Jul 05, 2010 | Hayward 1 HP Matrix Pump EC40 Perflex...
Proline pool pump SD-1--1N11XB
This sounds like you have a bad seal in your pump and the loose piece is probally a piece on the shaft of the motor called a water slinger. This is just there in case your seal goes bad and leaks water it will spin with the motor and sling the leaking water out and away from the motor so a small leak does not ruin your motor. But you will still need to replace your seal and "O" ring.
Sep 12, 2009 | Hayward 1.5 Hp Northstar High Performance...
I have a proline 2hp above ground pump. A snake
The impeller is still jammed you need to get it cleaned out. You can try with a pair of needle knose pliers if that doesnt work your gona have to remove the pump bolts that hold the motore to the pump pod. Remove the bolts around the motor and seperate it this will give you better axcess to the impeller. Clean it out and try to move it if the impeller will not spin freely with the debris removed the motor has burned up .
Jun 24, 2009 | Hayward Sp2607x10 Super 1 Hp Swimming Pool...
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
600 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
