Top and bottom of a4 copy is light but printing is ok. I have changed the drum but the problem continues. my machine is ir3300
SOURCE: my ir3300 xerox machine not print out.please solve thins problem.
How are you trying to print? You need N boot rom. Press Counter Check. Do you see IR3300(IR2200N) or IR3300(IR2200). If you see the N then you should be able to print with it. If not, you can't.
In Service Mode (to get into this press Additional Functions (button with * on it) > 2 then 8 > Additional Functions) go to Copier > Display > Version. What do you see for BOOT-ROM (does it have a N at the end?). For PS/PCL what do you see?
If your BOOT-ROM is N and you don't have a number for PS/PCL then call a technician to install networked system software.
If BOOT-ROM is not N, buy a Network Multi-PDL Kit C1 and get a technician to install it and load N system software.
If BOOT-ROM is N and you have number for PS/PCL check your IP settings. Make sure that DHCP is turned off. Set up your printer using an IP port with the static IP address assigned to the copier.
Use PCL5e or PS drivers, don't use PCL6.
SOURCE: I have this problem on my clients iR3300 copier a
check your drum volume and make sure not exceeded lifespan, clean up your scanner unit or replace your developing spacers and bearings,maybe also your developing cylinder.
SOURCE: sIR,i AM RUNNING IR 400
Greetings of the Day, Sir I am running in ir 400 and ir 600 machines good quality drum and toner company recommended sir, Please name and purchase procedure please sent my mail or phone
