Question about Pegasus Technologies Pegasus Toilet Paper Holder Chrome With Sand Black
Pegasus Dual Flush Toilet - How to repair damaged handle
Is there a way to repair the flush handle?
It is made from plastic and after 3 month already broken.
Can somebody tell me where to buy spare parts?
Homedepot is not having them.
  • Anonymous Mar 30, 2014
    Where can I get WaterRidge Repair Parts. The flush mechanism on the lid needs to be replaced.
  • 297 Answers
Any good plumbing supply company will help you. " Furgoson " i think thats how you spell it.
Posted on Jul 22, 2009
It will not flush properly .rudy
How to Troubleshoot a Flushometer
A flushometer consists of a metal pipe extending from the back of a toilet with a slender handle on the side that is used to flush a toilet. This type of flush valve is commonly used for toilets in commercial facilities to provide a durable and accurate flush delivery system. If the flushometer does not work properly, troubleshoot it and perform minor repairs. Common issues are often resolved quickly. If troubleshooting does not correct the problem, call a plumber for repairs.
Does Not Flush
1 Inspect the handle assembly. A broken handle or assembly will prevent flushing. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it with a handle repair kit
2 Open the main water supply valve to turn the water on fully. The water supply is normally turned on, but check to make sure it is turned on fully and has not been turned off inadvertently
3 Remove the flushometer's CP cover, the round cap on the very top of the pipe extending from the toilet. Then remove the inside cover directly underneath the cap. Inspect the relief valve. Replace it if it is visibly damaged.
Short Flush
1 Remove the CP cover and inside cover. The CP cover is located on the very top of the pipe extending from the back of the toilet. The inside cover is underneath the CP cover and the diaphragm assembly is located beneath the inside cover. Remove and inspect the diaphragm assembly. A damaged diaphragm assembly can cause a short and incomplete flush. Replace it if it is visibly damaged.
2 Replace or repair the handle assembly. A damaged handle can result in a short flush. If damaged, unscrew and remove the handle assembly. Replace the handle or repair it using a handle repair kit.
3 Remove the CP cover and inside cover to remove the diaphragm assembly. If a low consumption diaphragm is installed on a water-saver fixture or a urinal diaphragm is installed on a toilet fixture, replace it with an appropriate diaphragm.
Mar 04, 2011 | Sloan Regal Flushometer 111 Toilet 1.6 Gpf
My toilet handle turns but the toilet won't flush. i heard a snap and then it didnt turn to flush
Your attachment to the flapper valve broke...it is either a plastic connection or a metal chain type connection...easy fix.
Please rate me
Oct 13, 2010 | Pegasus Technologies Pegasus Elongated...
Flush mechansim
pegasus products are a home depot brand can get repair/replacement parts there or,there are multi plumbing supply companies online or can check ur local plumbing supply but most flush valves--flapper-parts can be changed or repaired with parts off the shelf at ur local hardware-wal-mart-home improvement stores
Jul 07, 2010 | Pegasus Technologies Two-Piece Round...
Flush handle is broken how do i get replacement parts its a two way flush
any home repair ,plumbing and most hardware stores carry repair / replacement parts
May 17, 2010 | Pegasus Technologies Two-Piece Round...
The toilet is very poorly desigend - the cheap plastic flush handle is not designed to carry the weight of flipping the tank within the bowl. Of course the handle broke off - what do I do now - short of...
You said it.
Pegasus stuff is designed to fail from what I've seen. Every faucet or fixture they have is prone to failure.
Go back to your place of purchase and have the part replaced under warranty.
Feb 03, 2010 | Pegasus Technologies Two-Piece Round...
I puchased a new Pegasus toilet about 6 months
it is filling up too much you can adjust the arm there is a screw on the side that adjusts the leval of water in the tank
Jan 22, 2010 | Pegasus Technologies Elongated 2 Piece...
Pegusas toilet.
I have the same problem .... I took it apart and found that there is not any screws, nuts bolts, washers .... what it is (was) is a piece of lead (like a sinker on the end of a fishing line) attached to the end of the cable, yes the cable, that hooks into the handle and into the top of the flush mechanism - that yellow plastic tube )the cable goes through it) I was able to take it apart and repair the end of the lead weight with a split shot sinker BB - is the size I used. I also had to deform and cut some of the sinker away since the hole it sits in, is small. When I went to Home Depot to buy/get a repolacement unit, one store told me to call the manufaturer -- Foremost and gave me the number, I lost that piece of paper now that I have time to call again, I was left on hold for 10 minutes the first time. 1-888-256-7551 http://www.foremostcanada.com/warranty.php
I just called and pressed a few buttons, waited 2 minutes, got a live person, she asked me what was wrong, I told her that my handle was just spinning, she asked for my model number 131-926 (found on the inside back of the toilet) when I purchased it (make this up, within this year ... and yes you have the receipt - she never asked for it, just that I had one!) she took my address down and gave me a client number .... tada!
Aug 10, 2009 | Pegasus Technologies Two-Piece Round...
Plastic under flush handle stripped.
If the threads are not stripped on the nut or handle it should be fine. IMPORTANT TO KNOW!!! These are left handed threads, Meaning they tighten up the opposite way of a normal nut and bolt. If the threads are bad or damaged, you will have to purchase a new flush handle. They are not expensive at all. $2 - $10 Dollars. But first try screwing the nut on by turning it to the left instead of the right.
Dec 31, 2008 | Pegasus Technologies Two-Piece Round...
Pegasus Technologies Pegasus Toilet Paper Holder Chrome With Sand Black Logo
1,005 people viewed this question
Top Pegasus Technologies Home Experts
john h
paulcarew
Are you a Pegasus Technologies Home Expert? Answer questions, earn points and help others
