Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
Key broke off in key switch on a 4 wheeler. What is envolved in changing this out? does it take special tools?
    Problem Solver:
  • 15 Answers
I had the same problem on my scooter. I used tweezers to pull the key out and then i took the bottom portion of the key to ACE hardware store. They didnt think they could remake the key but the guy i worked with was awesome. he cut the new key and it started my scooter. worked perfectly and it only cost $2.50 !!!
Posted on Oct 28, 2009
  • 60 Answers
The ignition switch itself is very easy to remove, after you unbolt the collinder/fender/control panel from the 4 wheeler, just unscrew the large ring on the outside where the key goes in and the hole switch will come off. then unplug the wire connectors that hold on the switch. Now you can try spraying WD40 into the key switch to loosen up the tumbler pins and turn the switch upside down to try tapping it so the broken key can slide downwards and come out (I would not try taking the switch apart, as you will end up having the pins fall out and not be able to put it back together properly). If the key does not come out after tapping it than you should take the switch to a lock smith and have them remove it for you and make a new key.
Posted on Nov 02, 2009
    Problem Solver:
  • 4 Answers
Dismantle ignition,noting connections colurs ect,bit should fall out
Posted on Sep 23, 2009
Wires are broke loose from the key switch on my 250 suzuki four wheeler witch wire sends fire to the plug
the key when on sends power to the ecm electrical control module this in turn sends it to the coils and then to the spark plugs get a wiring schematic for your quad and rehook them up to the key
Mar 29, 2015 | Suzuki Motorcycles
4 wheeler ignition replacement
what kind of atv are you working on?
Jan 18, 2014 | ATVs
Chip key problem
If I understand correctly, you broke a key off in the ignition switch and a piece is still in it keeping you from inserting a good key. If that is the problem then the actual ignition lock assembly will need to be removed. That usually takes a specialized tool to do. I would take it to a locksmith or the motorcycle dealer to fix...don't mess with it! It will cost more in the long run.
Dec 28, 2012 | Motorcycles
My key broke off in my ignition switch and i need to know how to replace it
Pretty much takes a locksmith or mechanic to do this repair, it takes special tools, typically not purchased unless you do lots of repairs.
Mar 20, 2011 | 1993 Lincoln Town Car
Key switch replacement
Go the the library and read the Chilton;s manual for replacing the ignition Key Lock Cylinder. It will show you what special tools that are needed with pictures as well
It is a long process to change and can not take the time to write 4 pages of instructions to you
copies of the pages from the book can be made there as well
Jun 08, 2010 | 1993 Oldsmobile Cutlass Supreme
Lost low on polaris 4 wheelers heard a pop and no more low
how do you fixs pull ropes for yamaha kodak
Aug 10, 2009 | Garden
Instrutions on changing a head gasket on a 93 volvo 850
well one of the easiest way of getting the instructions u need is to go to a mechanic shop a local one and ask them to run a copy of the head changing procedure and there they can give u all the nessacery info u will need and it will cost u nothing.or u can go to a local parts store and buy a manual or dvd on how to fix ur problem but one thing i can say is changing a head gasket on a volvo is a very difficult task too do i am a mechanic my self and there is alot of special tools and alot of know how envolved but good luck
May 18, 2009 | 1993 Volvo 850
Tools needed?
flywheel puller?
Jan 19, 2009 | 2001 Yamaha TW 200
Ignition switch
You need to remove the shroud so you can see the whole lock assembly.Once this is removed you should see a little silver retainer pin. While pushing in on the pin, rotate the lock with the key in it, until you feel the pin drop in. At this point you can start to pull the lock out. You may need a torx driver to unscrew some of the bolts, but there are no special tools needed to actually remove the lock assembly , besides a working key.
Aug 22, 2008 | 1992 Chrysler Lebaron
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
391 people viewed this question
Top Quad Cycling Experts
shaun taylor
Charles T Nevin
Charles T Nevin
Are you a Quad Cycling Expert? Answer questions, earn points and help others
