Question about Whirlpool Refrigerators
Where can I get the service manual for a Whirlpool Gold French Door refrigerator GI7FVCXWY00?
SOURCE:
rogrrabbit
  • 986 Answers
SOURCE: We have purchased a water filter for our Whirlpool
Most all Whirlpool refrigerators with a filter have the filter at the base where the 'kickplate' grill is. Simply turn it counterclockwise and pull it out. Reverse procedure to install new filter. No need to turn off water or anything like that. If you have a water filter light that requires resetting, press down and release the light switch 5 times within 10 seconds.
Posted on Sep 12, 2009
milten1
  • 1304 Answers
SOURCE: I have a Whirlpool Gold refrigerator w/french
you might be able to get a little room
look at the bottom hinge of the door
the one you want to lower
you should see a few spacers between
the bootm of the door and the top of the hinge
as well as being able to lower the hinge pin by screwing it down
Posted on Oct 11, 2009
blueextc3221
  • 15935 Answers
SOURCE: 2009 french door refrigerator whirlpool gold water
It appears your dispenser mico switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
caroldon
  • 17130 Answers
SOURCE: NEED OWNER MANUALS FOR WHIRLPOOL GOLD 25.5CU.FT. FRENCH-DOOR BOTTOM-FREEZER REFRIGERATOR-GI5SVAXVLOO
Please log on to the link and click with model number.
http://www.whirlpool.co.uk/support_support-landing.content.html
Posted on Nov 30, 2011
  • 2699 Answers
SOURCE: My Whirlpool Gold French Door Refrigerator GX2FHDXVD is leaking underneath. The pan is cracked. How do I remove the pan?
i don't think there is a pan in your machine,it's built into the bottom frame near the compressor where the water evaporates from the heat.most likely you have a blocked drain in the freezer or one of the water lines has a crack or the water valve is cracked and leaking.open the freezer door,look at the floor of the freezer to see if there's any ice there on the freezer floor,if so you have a blocked drain,where is the water leaking from,in the front of the machine or the rear,also do you have a water line hooked up to the machine?
Posted on Oct 02, 2012
Error code 2 Whirlpool Gold French door refrigerator
Check air damper door and triac for damper
Oct 27, 2016 | Whirlpool Refrigerators
Water leaking about once a week from french door fridge
Look in back on the bottom left in the area below the compressor at the plastic drain pan. Most likely it's cracked
Jan 03, 2011 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
I have a Whirlpool gold french door model # GI5FSAXBY02. The icemaker stopped making ice -please advise. Thanks. Charles Mara chrlsmara@yahoo.com or cjmara@cox.net
Could you double check your model number. I am unableto pull that model number up. You mentioned that your ice makehas stoppedworking. This could be several things, like water control valve,defective ice maker, defective ice maker thermostat and more. Let me know,Thanks, SeaBreeze b8e6bdd.jpgWHIRLPOOL PRODUCT MANUALS
Sep 26, 2010 | Whirlpool Refrigerators
I have a Whirlpool Gold refrigerator w/french doors, model GI5FSAXVY. The door on the right is set higher than the other, not allowing me to open my cabinets above. How do I adjust the height of the one...
Oct 11, 2009 | Whirlpool GI5FSAXVY Stainless Steel ...
ICE MAkER HANDLE PROBLEM
If your model is the Whirlpool Gold I can possibly help you.
Whirlpool Gold GD5NVAXSY need model number to got to service manual. Sorry, but manual people don't realize how many versions of refrigerators. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Jun 02, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerators Logo
52 people viewed this question
Top Whirlpool Refrigerators Experts
Bruce Denton
Steve Allison
Steve Allison
Norman Worley
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
