Question about Music
Can't turn on Roland Fantom G8 keyboard. Tried everything I could think of. Plugged in. Outlet works. Nothing else plugged in. Power turned on. Volume up. No lights. Nothing. Please help.
  • Anonymous Mar 30, 2014
    power cord is plug into piano keyboard and other end of power cord is plugged into outlet. power light on keyboard does not come on.
  • Music Master
  • 5,603 Answers
Check your power cord. Sometimes they break near one of the plug ends. Use an Ohmmeter to verify continuity.
Posted on Jul 26, 2009
When I plug the damper pedal into my Roland ep 77 the damper comes on and stays on no matter if the pedal is pressed or not pressed.
Try plugging in the pedal with the Roland powered down or off. With the pedal plugged in, turn the Roland on again. The Roland should sense the polarity upon power up. If this doesn't work, I have had those pedals get defective right out of the box, so try this...Get a ¼ inch guitar or signal cable and plug that into the damper jack. The cable will represent an open circuit polarity since nothing is shorting out the leads. See if the EP77 is sustaining or if it is not. Alternately, try shorting the guitar cable by laying a piece of metal across the top and bottom of the jack. A pocket or kitchen knife or any bare wire will do. If this does not work, your assumption about the power supply may be correct.
Dec 26, 2014 | Roland Music
My Roland G70 power up problem. .
Open up the Roland G-70 and check if all the connectors and flatcables are well seated. Check also if the power supply is working as supposed to.
Aug 30, 2012 | Roland Music
I have a very loud hiss/buzz sound coming from my Roland. It goes away if I lower the high volume knob. This just starred to happen recently. I tried changing connections from ch1-4 but no fix.
If this ties to a keyboard, make sure the keyboard and this are BOTH plugged into the same receptacle. You should send a higher level from the keyboard (turn volume up to around 70% or so) and use less volume at the input gain of this amp. Use more at master volume if the amp has one if needed. If the hiss is there with NO input cables plugged in and input gains at 50%, that is objectionable, the amp probably needs servicing. Unused channel gains should be clear down.
Apr 11, 2011 | Roland Elektronische Musikinstrumente...
Hello- my P95 sustain pedal does not work when plugged in but the sustain works when you disconnect the cord from the back of the keyborad
This is confusing... you say "the sustain works when you disconnect the cord"? How can that happen? and doesn't work when it is plugged in.
MOST sustain pedal problems are due to people using a different pedal than the keyboard is designed to use. It is very common that someone tries to use a Roland sustain pedal on a Yamaha and oof course it doesn't work because the Roland pedal is normally closed and Yamaha usually requires a normally open contact.
A FEW keyboards now check the state of the pedal input when power is first turned on and configure the pedal polarity accordingly. For these keyboards, make sure the pedal is plugged in before power is turned on.
Apr 02, 2011 | Yamaha P95 Digital Piano
My roland fantom xa turn on but dosn't log in it just show something like roland fantom xa in continue slide show
when i turn on my roland xa it's going on but it show on screen xa fantom and it gonig hang what i do
Feb 25, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
Roland fantom g8, problem, The last 2 octaves do not issue sound
Read page 135 regarding the note range settings. Look also for keyboard split information. You may have the keyboard set to NOT play notes in the top octaves for the particular voice you are using.
Feb 23, 2011 | Roland FANTOMG8
I have a Fantom S keyboard. I have to press the the F above middle C a lot harder than the other keys to get any sound. How can I repair this?
Hard to say as they are a very complex machine. However have you tried a factory reset - check the manual - its a certain key/button combination. You will losse any special settings but glitches are often solved by a reset. Good luck Bruce
Feb 13, 2011 | Roland Fantom G6 61 Key Pro Keyboard...
When i turn on the Fantom G8, it shows a blue screen with this message "Roland Fantom (S/W updator) (B)
Somehow you have activated the mode to download a new operating system into the unit. It likely is expecting the new SW to be presented form source such as MIDI, USB, or stick.
Get it out of that mode before something gets clobbered. DO a Factory reset which will consists of holding certain buttons and turning power on. Find this procedure in your user manual.
Feb 12, 2011 | Roland FANTOMG8
Music Logo
397 people viewed this question
Top Music Experts
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
