My two speed agitator will only agitate on one speed. Is this the motor or the timer?
  • 714 Answers
You can go to RepairClinic.com and they will help you with some suggestions. Goodluck
Posted on Jul 19, 2009
Sped Queen motor overload
It's 20 years old and you want to repair it?
Mar 19, 2014 | Speed Queen Washing Machines
Wwont agitate
In the circuit there is a module that works the agitation of the machine . It is an electronic device that moves the motor back and forth producing the agitation and is not connected to any other operation. Have it checked by a washing machine mechanic for failure.
May 05, 2013 | Washing Machines
70 Series Kenmore Washer Agitates in Heavy Duty regardless of switch selection
Yours is a 2 speed motor. Does it spin in 2 different speeds. If so, then it most likely is designed with only to agitate in 1 speed. If it only spins in one speed, then your motor is defective
Nov 03, 2017 | Kenmore 24032\24036 Top Load Washer
My washer fills with water,wont agitate but spins and drains
The agitate is a slow speed on a two speed motor. That said, there are several things
which can cause this. I have seen a bad connection on a motor plug do this.
This can often be seen as a dark spot on the semi- clear connectors.
Also a missing point on the timer (They can burn shut and pull off the contact). One way
to test the timer is to see if the washer will agitate on other cycle settings.
Third would be the motor itself. I haven't seen a partial failure ever.
One last thought, If you have a two piece agitator, the "Dog Agits" may be bad,
If you can grab the upper portion of the agitator and it turns freely back an forth, then
they have worn out. They are about 4 dollars. Take off the top plug/softener cap and there is a
bolt (usually 7/16th) that unscrews. Loosen this bolt counter clockwise and remove upper
assembly, The center part containing the agits can be removed and should be very
obvious as to their reassembly. Hope this helps.
Mar 10, 2011 | GE WDSR2080D Top Load Washer
Whirlpool top load washer no low-speed agitation. The unit fills, starts the wash cycle with normal agitation, but after a few minutes it just sits there soaking until the it's time to drain/spin. Drains...
Either the wire going to motor for non working speed is loose or damaged, or motor is bad. It could also possibly be timer not sending power to motor for that speed.
Sep 27, 2017 | Whirlpool Ultimate Care II LSQ9549L Top...
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Agitator not working properly
remove the agitator cap there is a 7/16 bolt in the top of the agitator remove it remove the agitator there are 4 little plastic teeth like pices in the top of the agitator call agitator dogs they are warn out. seperate the agitator remove and replace the dogs then put back together machine should work fine
Jan 20, 2009 | Kenmore 24032\24036 Top Load Washer
Inglis Washing Machine agitator not working right
washing machine will not aggitate will do the rest
Mar 27, 2008 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
